I got a swap meet tach a while back and went to hook it up problem was it started at 8Krpm instead of 1K. I pulled the cover back and it was in 8 cyl position. green wire tach, red ignition, white light and black grounded. Any ideas? its a cool looking tach and I'd like to use it.
That is correct but what is it grounded to? Mine was doing the same thing until I put a direct ground to the frame. Good luck.
