"Linear" speedo's?
Discussion in 'The Hokey Ass Message Board' started by Choptop, Apr 10, 2012.
  1. Choptop
    Choptop
    Which cars had 'em? Looking for something without the typical "sweep" needle.
    58 Edsel had the "compass" speedo, which is close...
    any others come to mind? Pics?
  2. Ole don
    Ole don
    Some Buicks in the mid 50's had the sweep.
  3. hotrod51
    hotrod51
  4. '66-'70 Rivieras (I think even Toronados, too) had a really bitchin' speedo that rotated. The speedo marker was fixed, and the ball with the numbers spun behind it.
  5. Choptop
    Choptop
    I'm seeing 61 Olds Starfire
  6. Choptop
    Choptop
    hmmmm... pretty cool... 67 Toronado speedo... keep the ideas coming!
  7. Choptop
    Choptop
    nice...
  8. squirrel
    Volvos....the last of the 544 had them in the early-mid 60s
    62 imperial
    Those are the only two I remember from my youth
  9. Dapostman
    Dapostman
    69 Lincoln had one.
  10. 52stude43
    52stude43
    64 to 66 T-birds had em
  11. What about the '56 Studebaker speedo that Brian Bass used in the Bass Coupe?
  12. Alan:
    1955-56 Pontiacs used a similar idea only it was in an arc instead of straight across.It looked like the liquid in a thermometer moving in an arc around the speedo.What it actually was was a clear and red disc that rotated and only a small portion of the red was exposed.Looks pretty neat.
  13. rbroadster
    rbroadster
    Pretty sure '59 and '60 Buicks also had the speedos that spiraled from left to right as the speed increased.
    Sorry, no pics handy.
    - RBR
  14. Atwater Mike
    Atwater Mike
    '58 Dodge had a wide cylinder like an Edison record..It rolled, and the color changed from green to yellow to RED, (got bright red at 100+!)
    Scary for the passengers watching the speedo...
  15. papajohn
    papajohn
    '60 Olds used a big drum that changed color as speed increased.
  16. Finnrodder
    Finnrodder
    from Finland
    Volvo Amazons had them too
  17. TBone69
    TBone69
    from NJ
    55 Buick, Had one in a 55 Special I used to have. Sorry no pic of the speedo
  18. pasadenahotrod
    pasadenahotrod
    from Texas
    How about 54 Buick? They had a narrow speedometer with the cable inserted at the end rathet than the back.
  19. Phillips
    Phillips
    60 Olds has a way cool thermometer looking drum setup, I am assuming that 61 listed above is the same but you cannot see the color since it isn't moving.
    EDIT - I see papajohn already mentioned this one sorry
  20. CutawayAl
    CutawayAl
    from MI
    The '59 Olds had that same type of speedometer.
  21. lolife
    lolife
    57 Desoto. It was a cardboard tube inside that rolled, and the red color was a triangle shape on it, so the more it turned, the more red was revealed in the window.
  22. Roadsterpu
    Roadsterpu
    1956 Buicks had a linear speedo that had a red drum that turned to the speed.
    Youtube video of it working. Video by mattnattig
  23. gatz
    gatz
    '57 Dodge also, but IIRC, it was only RED...maybe due to it being a Coronet ?
  24. Dino
    Dino
    '60 Plymouth, if I recall correctly.
  25. gnichols
    gnichols
    from Tampa, FL
    One of my HS buds dad's cars had one like that, I think. I also remember it also changed colors, as the speed increased. Is that the same year as this one? Gary
  26. LAROKE
    LAROKE
    I seem to recall that the 60 Plymouth speedo had little tabs (like a old-fashioned cash register) that would pop up in five or ten mph increments as speed increased.
  27. Choptop
    Choptop
    here is the dash and speedo pod. VERY cool looking. The speedo is linear... if thats how it works (cash register tabs)... that would be very cool as well.
  28. atomickustom
    atomickustom
    It's been years and years since I owned one, but I believe late 1960s and/or early 1970s Lincolns had one that was a read bar that moved to the right? I also owned a '62 so it might have been that one, but I'd swear it was my '72 Town Car??
