Any Hudson guys out there? Is anyone reproducing the the rubber gasket that goes between the tailight lense and housing on a '49-'50.
The original rubber had a channel running through it and wrapped around the perimeter of the lense. Can I buy that somewhere?
I don't know about your part specifically, but I'd check in Hemming's for Hudson parts guys. Also, there is a Hudson Fourm on the AACA site and you could ask your question there. (http://forums.aaca.org/f166/)
Thanks, just emailed both of those contacts. John, I found those, too...but, those are the housing to body gaskets. I need the lense to housing ones. Appreciated, though.
This may sound cheesy but I just used some thin adhesive weatherstrip for mine. I cut it to fit. So far it has worked good.
From my Hemming's,you might try these folks: patwalshrestorations.com [email protected] or 520-568-2911 classicautopartsonline or 208-762-8080
The pads you are looking for are available from KGAP automotive parts. http://www.k-gap.com/ On line catalog lists them as item 160. Taillight to body pad 1948-51 Super 6, Pacemaker - Taillight to body pad <NOBR>PRICE: $25.00</NOBR> Best to call // to order... leave msg as this is a family biz. Just realized you are neighbors... maybe you can go by and pick up what you need...the biz is just off "the 15" south of the 10 Cheers from Texas Ken
Those are the housing to body gaskets. I need the lense to housing ones. Appreciated, though. <!-- / message -->
