12 volt to 6 volt jumper cables
Discussion in 'The Hokey Ass Message Board' started by Bradlee T, Mar 6, 2012.
  1. Destralo Roach
    Destralo Roach
    I have the opposite problem, every one is always asking me for a Jump!? My Six volt car AlWays Starts and runs...:cool:
    .....Roach.
  2. Mike51Merc
    Mike51Merc
    Um, if you had an extra 6 volt battery, why would you need a jump in the first place?
  3. Mike51Merc
    Mike51Merc
    I bought a NAPA Industrial 6V battery. No complaints. You gotta make sure you buy a fresh one. Since they don't sell a lot, they tend to sit on the shelf for a long time.
  4. chappys4life
    chappys4life
    from Austin, TX
    What is the fun in that. Being 6volt makes you a cool kid and bragging rights.
    I am all about 6v optima's. Seems like my Napa batteries where lasting a year (went through 2 both not being covered under warranty - no idea why had a receipt too). Installed an optima and wow its crazy how much better it starts and how much easier it starts in cold weather.
  5. tubman
    tubman
    Two things : I agree with the OPtima choice; make sure you turn the radio off; ask me how I know.
  6. mrconcdid
    mrconcdid
    from Florida
    Thats what i was going to say.
    MrC.
  7. Truckedup
    Truckedup
    Only drive manual trannys and be sure to park on hill
  8. revray
    revray
    I agree!
  9. Gretschplayer
    Gretschplayer
  10. d2_willys
    d2_willys
    from Kansas
    Curious, when did you buy your last 6V Optima? I had one that last over 12 years. But I have also heard that the latest Optimas are made in Mexico and are not very good compared to the older 6V Optimas.
  11. d2_willys
    d2_willys
    from Kansas
    55 Ford has either a stick or a Furdomatic, both of which are push start-able! Get it up to speed and shift to 2nd (stick) or Lo on the Furdos.
    You can also get one of those battery booster boxes. They have a gel cell and do not generate alot of amperage, just enough to charge up the dead battree.
  12. d2_willys
    d2_willys
    from Kansas
    In some of the older parts houses they are near the JOHNSON RODS!:eek:
  13. Ok ill bite. How do you know?
  14. 40FordGuy
    40FordGuy
    Mr48Chevy,.... A correction,...ALL Ford 6 volt systems were POS ground,......They went to the 12 volt neg ground industry standard in 1956. (Which likely made accessory mfgrs very happy) !
    4TTRUK
  15. The guy at Autozone said they were out of them. He did sell me a new set of muffler bearings.:confused:
  16. blowby
    blowby
    from Nicasio Ca
    Bumping an old thread with some good tech advice, particularly page one. :)
  17. Thanks, that was great. Brought back memories of the star wars air cleaner thread.
    lothianwilly71 likes this.
  18. southcross2631
    southcross2631
    When I did the 6 volt alternator conversion on my 53 ford. I had to change from positive ground to negative ground. That was years ago , do you still have to do that?
    Fix the carb first and then worry about the battery.
  19. Kerrynzl
    Kerrynzl
    Don't be silly...... only use one cable [why wreck a good set]:D
  20. Bruce Lancaster
    Bruce Lancaster
    "Mr48Chevy,.... A correction,...ALL Ford 6 volt systems were POS ground"
    HEY!!!! What's more FORD than a Model T??? Negative ground, on the ones that have batteries. No one knows what the hell is going on with magneto only ones...they're all parapsychology, not engineering. And good luck finding anything to clip your jumpers to!!
