Am cosidering removing the Spal fan and installing a multi-blade fan. I have the clearance in front of the waterpump but not outermost groove on the crank pulley. If possible I'd like to machine off that groove leaving the inner groove that runs my single wire Delco Alt. Am uncertain about external balance problems on the 302. The pulley has a small counterweight under that groove and would be removed with the machining.
I think so too. I've swapped multiple pulleys on my SBF with no problems. The balance is in the balancer.
I'm not quite sure of what year 302 you are working on because the balance changed in '79-'80 from 28oz. to 50oz. Early 302s used a 3 or 4 bolt on lower pulley. Do you have any pics.?
got a 302 in my coupe used a crank pulley off a p/up cut 2 groves off of it still on it seams to be ok
