Where to buy a 1962 Cadillac DeVille transmission filter???
Discussion in 'The Hokey Ass Message Board' started by garagedoreen, Jan 25, 2009.
  1. garagedoreen
    garagedoreen
    from LA,CA
    So I just bought a 1962 Cadillac Couple Deville complete and im doing a once over on the whole motor and trans. Changing the fluids, filter, ignition parts and so on. So what happen was that I pulled off the transmission pan to change the filter. I had bought a transmission filter from the part store and it did not match. so I returned it. And I went everywhere to find a match. couldnt find shit. I went to AutoZone, Pepboys, Kragens, Bumper to Bumper, Napa and some other local autoparts store and they all didnt have one. And the one they did give me was the wrong one. The one that they gave me was for a 67 or something. I think they have the wrong part number or something. I searched the web and couldnt find anything either. Anybody have any idea where I can get one?? I have a 1962 Cadillac Couple Deville 390 engine with a 4 speed hydromatic transmission..
    Thanks.
  2. Squablow
    Squablow
    Does that even have a filter on the tranny? I think that has the slim-jim tranny, like my '64 Olds 98, and it might have a screen on the pickup but I don't think it has a replaceable filter on it. I could be wrong, but I'm guessing that's why you're having a hard time finding one. The parts houses are probably giving you a TH400 filter by default.
    If you're not used to driving that car, it'll feel like the tranny is slipping. At a dead stop you can take your foot off the brake and not go forward, takes a little throttle to get moving, and the shifts are very soft. I thought my Olds trans was shot the first time I drove it, but apparently that's just the way they are.
    I also remember someone telling me they are controlled by vacuum so if you have your idle set high or if you have carb problems you'll feel it in the trans.
  3. Flop
    Flop
    we rebuilt my buddies and couldnt find a new filter we cleaned the hell out of what was there
    they are controlled by a tv rod squawblow ..if thats outa whack you will have bad shifts and a feeling of slipping
  4. squirrel
  5. squirrel
  6. Squablow
    Squablow
    Or, I could be totally wrong. It's a possibility.
    Anyways, what is a TV rod? How does that work?
  7. stuart in mn
    stuart in mn
    Those old jetaway transmissions had a linkage rod that attached to the throttle linkage, it controlled when and how smoothly the transmission would shift gears. The adjustment was pretty sensitive, get it wrong and the tranny wouldn't shift very well at all.
  8. r8odecay
    r8odecay
    I"ve had on that had a stuck check valve or something too, wouldn't shift out of first,.. did a reverse slam and cleared it up. Your results may vary.
  9. d2_willys
    d2_willys
    from Kansas
    TV means throttle valve, and in your case has the TV rod from carb to transmission. Normally this is adjusted for the TV lever (where rod is connected at trans) to be at the farthest rear position at idle and at farthest forward (toward engine) when wide open throttle. If this is not adjusted correctly shifts will be wrong and the transmission will slip.
    You have a Dual Coupling hydramatic (known as Jetaway by Olds, Stratoflight by Pontiac, and Superhydramatic by Cad). You do not have a Slim Jim, never used on Cadillacs.
    Go with Squirrel's link for the filter. Really dissappointed that Rockauto has the wrong filter listed, they are usually pretty good at accuracy.
  10. garagedoreen
    garagedoreen
    from LA,CA
    Thanks for all the reply
    yeah, i checked out that link. Ill give them a call and see if they have it in stock. but wow. 65 dollors for a trans filter kit! thats alot. Ive only remembered paying 15 to 20 bucks for a kit before. I guess its because this trans is so old i guess. but yeah I guess i cant be complaining. At least somebody has it. and I probibly spent like 50 bucks in gas driving around all the local autoparts store already.
    Yeah, i need to adjust my TV rod too. so what is it again.... idel the TV rod should be all the way to the rear and full with full throttle the TV should be pulled all the way to the front?? what is its "normal" position on the transmission??
  11. garagedoreen
    garagedoreen
    from LA,CA
    does anybody know what whats the model code for that transmission? Or does any body make a high performance upgrade for the filter pickup?
    thanks again.
  12. roughneck424
    roughneck424
    google USA PARTS they have a good supply of OLD Cad stuff, Buick & Olds also
  13. garagedoreen
    garagedoreen
    from LA,CA
  14. squirrel
    that's a Chrysler filter.
  15. Don't you have a NAPA store by you!
    they usually have a lot of Parts for Older Cars or a Trans Shop mite have one
  16. Cirilian
    Cirilian
    He said he went to NAPA in his original post???
  17. garagedoreen
    garagedoreen
    from LA,CA
    yeah, i think all these online parts store and auto part store data base has it all wrong. I think they all have the turbo 400 transmission filter for the pre-62 Cadillacs or that Chrysler filter.
    I got the phone number to Fram. so ill give them a call tomorrow when they are open and go from there.
    Fram and WIX online dont have a part number for them. and I searched everywhere online.
    Its funny.. Im sure Im not the only guy in the world thats building an old 60s caddy, I cant believe i cant find any info or part for this thing. I was thinking this is a pretty common car. but i guess not.
    the search goes on!!!!!!
  18. Pompadork
    Pompadork
    There is no filter. its a screen. autotrans.us has them, but they are not cheap. Welcome to the world of cadillac.
  19. garagedoreen
    garagedoreen
    from LA,CA
    ohh man... thanks....
    Thanks for the link. Ill give them a call...
  20. d2_willys
    d2_willys
    from Kansas
    You read it correctly, this TV rod tracks the throttle linkage and adjusts the transmission according to throttle opening. Idle= all the way back, WOT= all the way forward (toward engine). No so called normal positions, all it should do is move freely as the throttle is opened and closed.
  21. garagedoreen
    garagedoreen
    from LA,CA
    awesome thanks.
    I found the filter and gasket. I found it an a trans shop in Glendale. They had it. 65 bucks for the filter and 10 bucks for the gasket.. man... thats alot because it is about15 bucks total for almost anyother car... but i guess its done now.
    Thanks again.
  22. flyingfreeman
    flyingfreeman
    Check Fatsco Transmission in NJ. They are awesome!!
    They have other parts like the Detent Spring (holds the gear shift selector in the proper position) which I had break on my 61 Cadillac 4 speed overdrive transmission.
    http://www.fatsco.com/
  23. joseangel_1976
    joseangel_1976
    hey man i'm from LA too here near glendale in the Los Feliz area. Do u know the name of the trans shop in Glendale? I'm also trying to find the filter for the transmission.. My car was stored for 10 years and barely got it running. took it to the mechanic to go get fixed for points and all of a sudden my tranny was out. i was so pissed i took my car back to my house. it's not doing anything. it just slips.. wondering if lowering the pan and draining out tranmission oil and putting back the filter and gasket would make it run again. thanx
  24. Cirilian
    Cirilian
    It's always a good idea to replace the filter after they've been sitting but before you do that make sure it has enough fluid in it.
