so i scored a 64 mustang gas tank. i wanna put that in my car (64 galaxie) i was wondering what gauge would work since im pretty sure mine wont work with the stock mustang sending unit any help would be great thanx
Mustang tank formed the floor of the trunk and held in place with screws around the tank edge flange; Galaxie tank mounted under the trunk floor pan and held in place with straps, and I suspect was larger in capacity. Plus the Galaxie sender mounted through the top of the tank versus the front on a 'Stang, which may actually work in your favor, But, do you REALLY want to hassle with this? I understand wanting to be frugal, but why not sell the Mustang tank, save up some $ and get a correct one?
OP's question was what gauge to use as he thinks his won't work. The gauge on the dash, I assume. I see no reason why it would care if the sender is Galaxie or Mustang.
I think the correct one is about $500.00. if my memory is right. Mustang about $150.00. I agree the 64 gauge should work.
i dont know why youd want to do this that stang tank is only a 16 gallon or so when the galaxies tank was around 20 if you have a f/e under the hood your gonna want the extra gallons but as others have said you shouldnt have a problem with your stock guage and the stang sender on a side note the 70 mustang tank (same mounting as the 64 holds 21 gallons)the 69 tanks hold 19
Yes either sender will work. Most Fords up to 1989 used the 73 Ohms empty to 10 ohms full sending unit. Which Fuel Tank Sender Do You Really Have? 0-30 Ohms (GM Type '64 and earlier) 0-90 Ohms (GM Type '66 and later) 75-10 Ohms (Ford Type '86 and earlier) 16-158 Ohms (Ford Type '87 and later) 90-0 Ohms (Toyota and Nissan '85 and later) 240-33 Ohms (Standard Aftermarket)
