Just wondering what would be the best way to fix these drip rails and jambs. The car is almost rust free but the dents Was picked up with a chain and it kinda messed up things. Roof is not straight in the top rear area but should be able to straightened out OK. Drivers side is damaged for about 12" and has been welded up sometime and passenger side is crushed where the chain was. Passenger side Drivers Side
Been there and done it. If I had to do it again I will change the roof before trying to change the rails. They are pinch welded in between the roof and lower jambs. Thats why ya see so many bondo formed ones. or just gone. Hang on! find a roof or just tack weld some replacement sections in. and mudem.
Hey, For the shotgun side of the driprail I'd build a "tee-stake'' type dolly/spoon from round stock and flat steel . Choose the round stock that best fits the crown of the driprail shape. To straighten the rail, you can rough out some of the damage with pliers wrapped in 200 m.p.h. tape so tha jaws of the pliers don't do more damage to the rail. I'd heat the ding up with a torch to a cherry red colour, and work your ''tee-stake-dolly/spoon'' on dolly, until you have it straight, On the driver's side I'd open up the rail with a screwdriver, worl your 'tee-stake ' behind, and straighted it as before. For the repair to door jam Cant Rail, I'd weld a bolt head into the deep area of the dent, attach a small length of chain & a nut & washer to the welded bolt head, and use a come-a-long to pull the damage out. Be sure to hammer around the damaged area to help releave pressure in the damaged area. Use a straight edge to gauge that the rail is level & straight to the opening. These don't need repalcement, just straighting & derusting " Humpty Dumpty was pushed "
Thanks. Will do my best to get them straight. I was thinking a complete roof replacement. Guess that's why I am not a body man.
Do not know what happened. Was a picture of the drip rails. Posted these pictures on another post..................
Sounds like a unique project-may start a trend. Drip rails on manifolds huh? Just funnin! Like pimpin said, straighten em or if above your skill level, pay somebody for a couple hrs skilled labor. may be a bargain!
who knows you could be on to something? drip rails on manifolds for cars with no hoods, i bet theres a market for it.
