I've been looking for this type of grill mesh and haven't been able to come up with a supplier. Anyone have a source? Thanks; GaryC.
You can also have it water jetted out of stainless, or aluminum to your dimentions and or hole size and spacing. I have a local buddy with a water jet business that does all kinds of this for me and other hot roders. Going this route you only pay for the piece you use, if purchased from a supplier you may have to buy a whole or half sheet...just a suggestion.
McMaster-Carr is about the easiest to deal with if you want a partial sheet. They usually show smaller sizes than full 4x8 sheet. Check this. http://www.mcmaster.com/#stainless-steel-wire-cloth/=etyfi1 It looks like the smallest sheet they sell is 24x48 though.
McNichols Co. 1-800-237-3820 - They'll even send you free samples if you request them. They have stocking centers around the country. They're also on line.
the pic is kinda lo-res so its hard to see the pattern, but if all else fails, try M&K Metals in Gardena, CA
Not sure if this is the style or size you want, but.... http://www.speedwaymotors.com/Radiator-Grille-Shaker-Screen-31-x-19,3546.html
