Projects My 1931 Ford Pickup Project From Arg.
Discussion in 'The Hokey Ass Message Board' started by LeaBlender, May 9, 2011.
  1. Great project! Hoodlums Worldwide.;)
  2. It will install a 302 engine with almost 300 hp, keep in mind that the Southern routes are not the same as North :eek:
    Lea.
  3. Hey guys, I commented that it is ending with the chassis, only some details remaining laburar and now with the cabin!
    I leave what has been done lately images on the front:
    On the other hand, got the mask of 32! (fiber, needs to be repaired and perfect!)
    Regards, Lea.
  4. Evel
    Evel
    1. 60s Show Rods
    It always nice to see hot rods and custom in Argentina!!
    my whole family is Argentine.. mmmmmmmmmmuuuumm milanesa
    Look forward to seeing more of the build...
  5. Veo que viene rapido el tema Lea.... , yo tambien pense en poner un eje de chevrolet una vez pero luego deja la idea atrás porque era para una baquet Ford A para bajarla un poquito de adelante y al poco tiempo arme todo original para no tener que laburar tanto con el eje delantero y cualquier otra cosa que se pudiera presentar trás colocar el eje de chevrolet... Buena suerte con el proyecto...
  6. Nice Evel... milanesas con papas fritas...
  7. Thank you very much for the comment! when you want to send a packet with Milanesas stuffed with ham and cheese! are explosive!
    Lea.
  8. George G
    George G
    Great work!
    I have been in Argentina and will be coming back! Great meat.
    Welcome to Hamb
  9. Tank´s George!! ;)
  10. kopperkart
    kopperkart
    from Wisconsin
    Keep posting progress pictures for our enjoyment. You are off to a good start on a fun truck. Other pics of the car scene would be great too!
  11. Hello friends from the north! I commented that it has completed the work relating to the chassis, the last weekend I spent positioning the cabin, as pedal, making the ends of bolts and final details.
    The next weekend will continue with the chopper!!!
    I attached pictures of the process:
    Details:
    Receive protection for the cabin
    Construction of pedals
    Coming soon...
    Thank you very much for the comments and for me is a real pleasure to share all my hard work with you. if you have suggestions feel free and welcome.
    Thanks for letting me be part of it!
    Greetings!
    Lea.
  12. OahuEli
    OahuEli
    from Hawaii
    I like those pedal arms. Are you going to leave them open like that? Thats pretty cool. Like the diamond plate too.
  13. I leave you a preview of what I was doing today
  14. OahuEli
    OahuEli
    from Hawaii
    Did you make vroom vroom sounds? :D
  15. I happened to comment that I shrunk the space!
    Process Chopp'd!
    Diagramming structure reinforcements... pre-weld!
    Reinforcements installed:
    Level and position doors:
    It is recommended to recharge before going to the cutting process!:
    Lunch time "Chorizo ​​Pomarola"!:
    Measuring and positioning lines for cutting:
    Moving down lines, tape and butt plate for furniture that has a lot of rigidity and keeps the line right with normal paper tape moved the line to the second cut:
    Cut studs, started the cut with conventional grinder and continued straight jigsaw to cut the studs and wood:
    Ceiling outside (playing a bit):
    The kid wanted to ride:
    Starting the second cut:
    Once completed, the roof was positioned at its new height:[​IMG]
    Oxyacetylene Welding both parties:
    They reviewed the entire record sldadura with Flaps and job done![​IMG]
    Embrace and greetings to all!
    Next step, cabin floor ...
  16. swissmike
    swissmike
    Great fabrication! Looking forward to seeing more.
  17. El Coral
    El Coral
    from Argentina
    My Friend!!!!! I want route already!!!!
  18. That is one cool ride you are building, thanks for the updates.:D
  19. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Very cool build! Just one comment; the rear radius arms mounted to the outside frame rails, and rigidly connected to the rear axle are a concern. One may break if you drive on the street as the rear axle articulates over bumps/uneven surfaces. OK for drag racing on flat surfaces, but driving on streets may become a problem.
  20. Boones
    Boones
    from Kent, Wa
    1. Northwest HAMBers
    very cool project. I have a 31 PU also that I will build someday. you are doing good
  21. Cool build dude !!!!
  22. Wow,great progress.
  23. D.G.F
    D.G.F
    from Las Vegas
    very cool build! like the video.
  24. ntxcustoms
    ntxcustoms
    from dfw
    WOW someone gas welding like days of old. Looks like a bunch of fun! Keep us posted.
  25. OahuEli
    OahuEli
    from Hawaii
    I liked that video! Looks like you guys are having fun down there!
  26. Evel
    Evel
    1. 60s Show Rods
    Fantastico!! looking good amigo..
  27. larry woods
    larry woods
    from venice fl
    Absolutely amazing! I am enjoying the engineering going into it. Do you have brakes and hubs for the chevy axle. It is my understanding 51-54 will fit but need a spacer. Not sure what the spacer is. I have 38 chev p/u in my coupe and still have the old brakes w/ six bolt! domebody on here should be able to spell it out for us. Good luck with the build it is looking CALIENTE'!
  28. Thirtycoup
    Thirtycoup
    You guys are having waaaaaaay too much fun!! Very interesting build for sure, I'm ENVIOUS of how much fun you are going to have when you finally get it on the road down there, a real head turner for sure. Now give us some more updates!!
    Good luck, Mike
  29. Mac30
    Mac30
    1. S.F.C.C.
    Looks great! How much was pullet out of the top?
