buggy spring rear suspension????
Discussion in 'The Hokey Ass Message Board' started by gravelpete, Jul 21, 2011.
  1. gravelpete
    gravelpete
    from canada
    Hey, just wondering if anybody has any info that can help me out? I have a 34 ford pu with a 8" rearend, buggy spring with a triangulated ladder bar set up and a pan hard. My problem is when I step on it hard it wants to change lanes and feels like the rearend is twisting, it handles good around corners and rides okay. I do not have any preload on the pan hard bar. I run regular shocks aswell. Is there any way to keep this from happening? Thanks
  2. MODELA30
    MODELA30
    SHOW US SOME PICTURES TO SEE WHAT YOU GOT. Knuck From Indiana.
  3. F&J
    F&J
    x2, pics will tell the tale of why the rear is steering the car.
  4. need louvers ?
    need louvers ?
    The first thing that rings a bell is a panhard rod with a buggy spring... Not that it is right out bad, just not necesary and could be putting things in a bind under acceleration.
  5. Dirty2
    Dirty2
    Do you have a locker in it ?
  6. need louvers ?
    need louvers ?
  7. wsdad
    wsdad
    Check for worn parts.
  8. gravelpete
    gravelpete
    from canada
    no spool or locker, everything seems tight and it was worse with no pan hard bar. truck 014.jpg
  9. gravelpete
    gravelpete
    from canada
    Sorry, these are the best pics I got right now and it does not have the pan hard bar installed in these pics. Thanks
  10. Dapostman
    Dapostman
    How much squat does it have under hard acceleration?
  11. Dale Fairfax
    Dale Fairfax
    Are you sure the rear end is "twisting"? It may be squat aggravating bump steer.
  12. gravelpete
    gravelpete
    from canada
    Not sure on the squat, I assumed it was twisting and that was why it seemed like it was changing lanes. Does the look of this set up look okay? What should I check? Thanks again
  13. ANDEREGG TRIBUTE
    ANDEREGG TRIBUTE
    from Bordertown
    carefully put a jack under the rear diff yoke, and slowly jack upwards and see if there is any obvious deflection (simulating some axle wrap up) I would start there. And a pic of your spring perches on the axle may help us out as well...
  14. gravelpete
    gravelpete
    from canada
    I will get better pics tommorow and I will check that.
  15. junk yard kid
    junk yard kid
    does it change to the right lane? or the left?
  16. gravelpete
    gravelpete
    from canada
    It wants to go to the right, it does not shoot to the right but it seems to twist to the right. It's hard to explain, and probably hard to diagnos over the computer. Thanks
  17. fordor41
    fordor41
    make sure panhard bar is as long as possible. short bar causes the rear end to travel in a circular motion while going up and down.
  18. need louvers ?
    need louvers ?
    How about your rear shackles? Are they hanging at a 45 degree angle or more 90 degrees to the spring and mounts? Lots of questions, I know! 'Nother thought, which side is your panhard rod swung from? Right framerail or left?
  19. gravelpete
    gravelpete
    from canada
    Left frame rail.
  20. Ned Ludd
    Ned Ludd
    Sounds like a torque reaction thing. Have you got any torque numbers for your engine? What's your first gear ratio? converter stall? rearend ratio? What sort of spring stiffness have you got at the back?
    Lots of torque, low first, high stall, short rear, and soft rear spring, and it could be engine torque is trying to twist the entire car clockwise. More roll stiffness at the back will fix that, but then you'll need more roll stiffness at the front to trim out the resultant oversteering tendencies, and ideally some frame stiffening to get that to work.
  21. Dapostman
    Dapostman
    I find with my O/T daily work truck, if the rear tires are lower pressure than the front, it feels as though the rear end is braking loose. you could try lowering the front tire pressure to see if it helps.
    Squat is the rear end of the body/chassis dropping on acceleration, raising the pivot point of the ladders can give you anti-squat, or even lift, which increases rear traction, if you raise it enough, but to much anti squat can cause brake hop.
