Projects 1954 Chevy 3100
Discussion in 'The Hokey Ass Message Board' started by speters, Jul 18, 2011.
  1. speters
    speters
    Back in December my father purchased a 1954 Chevy 3100 and I have decided to finally start our build thread. We bought the truck from a local artist who had been restoring it on and off for a few years. He decided he wasn't going to finish it and we picked it up.
    The day it became ours
  2. speters
    speters
    Since my father does not have the skills to restore the car he enlisted the help of a local guy who builds some amazing hot rods in his garage. Alex Velis has been building hot rods since he bought his first 32 at age 13 and has turned out some spectacular cars in western Mass. We dropped the truck off and I took some shots of his place.
    His barn
    Our truck inside
    His place is full of hidden treasures! A 32 frame next to our truck
    Tailgate under the pile
    A rough cab corner
    This looks good
    Fenders on the ground
    The dash
    The seat
    The former owner had done some serious cleaning on the frame
    Firewall
    Cowl has some holes but otherwise clean
    Another dash shot
    Parts
    More parts
  3. speters
    speters
    Doors
    New front and rear glass
    More shots of Alex's treasures
    Mustang on the lift
    Pile of 33 and 34 frames
    Ranchero under the mustang
    34 4 door hiding behind a flathead
    34 tudor on a shelf
    better make that 2 34 tudors
    36 Ford truck
    Fenders galore
    32 frame on the rotisserie
    AND THE REAL TREASURE
  4. speters
    speters
    Me welding up a cab dolly
    This will do
    Time to take it apart
    Not good
    Took out the gas tank. We will run one under the bed
    Frame back in
    Stripping it down for a C.E. IFS and Ford 9"
    Drilled out the front
    Rear frame repair
    Boxed for added strength
    Working on the power brake setup
  5. speters
    speters
    Time to get the powerplant in order! After selling the 235 we decided to be a little more unique and pulled this 401 Nailhead out of Alex's collection.
    We decided to open it up and see how it looks
    One cylinder needed to be sleeved since some moisture found its way in. Otherwise the motor looked great. We were very inspired by Ron Myers nailhead and want a similar look.
  6. speters
    speters
    Starting to mock up the 9"
    Jump to the frame almost done
    9" looking great
    Alex and my dad talking shop
    Time to mock up radiator
    Time to work on the tank and bed
    Rex the shop dog working hard
    Frame is almost done it just needs some brake lines and fuel lines
    Bed mocked up and up on the lift to make room
    Hanging the doors to start on the sheet metal
    Cutting away bad metal
    Not good
    More cut away
    Here was the 235 when I sold it off to a local guy for his 46 Chevy truck
  7. speters
    speters
    Now we are almost up to speed. The new floors and in and the rest of the cab sheet metal is almost done. The motor should be out of the machine shop soon.
  8. speters
    speters
    Some eye candy waiting for the motor
    Powder coated silver
    Sanderson Headers
    Tested the paint on a spare set of heads
  9. speters
    speters
    113 views and no comments????
  10. ok, that gas tank looks like it hangs down too low.
  11. Woody's Hot Rods
    Woody's Hot Rods
    That's going to be killer! Love the Nailhead!
  12. speters
    speters
    I will have to take a straight on picture from the back to show how the tank sits
  13. chevymike
    chevymike
    Sweet build. Engine should look sweet when all together.
  14. POLYFRIED 35
    POLYFRIED 35
    Nice start .... looking good!
  15. speters
    speters
    Got a set of old wheels powder coated and just got trim rings and spiders yesterday
  16. mastadon
    mastadon
    Nice build,you guys are fast.What gear in the 9 inch and what transmission is that?
  17. speters
    speters
    3.70 gears in the 9" with posi and the trans we have is a GM T5 Borg Warner 5 speed with a Bendtsen's adapter and a Lokar shifter
  18. classicdreamer
    classicdreamer
    from nyc
    1. A-D Truckers
    looking great! I am building a 54 as well. keep it up
  19. whid
    whid
    nice.....going quick......whid
  20. seabeecmc
    seabeecmc
    Friends don't let friends use Bendtsen's.
    Great project keep it up. Ron
  21. speters
    speters
    Tires are mounted
  22. Mr48chev
    It looks like you guys have really been thrashing on it these past few months. And it is starting to look good.
  23. speters
    speters
    Thanks! It should be in paint sooner than later. We have to figure out a good way to straighten the top rail of one of the bed sides. It is bent in a little and will take some effort to get right.
  24. leroys85coupe
    leroys85coupe
    from usa
  25. speters
    speters
    Yesterday we moved the body back onto the frame in order check out motor clearance and make sure all our patches came our right. So far so good!
    We can't figure out mounting the passenger side inner fender. The driver side has this bracket but it doesn't look like the passenger has one. Any input?????
  26. D-man313
    D-man313
    on my 49 the driver side bracket was rusted out, so i made my own mounts. on the driver side, the inner fender sits farther away from the firewall than the pass side. so on the driver side i used 3 all thread couplers(because they are longer than an average nut) and welded them to the firewall, so i can just bolt the inner fender right to the firewall through the couplers. i did the same thing on the pass side, but welded a regular nut to the firewall. because the pass side is closer to the firewall. hope this helps.
  27. shinysideup
    shinysideup
    from ruskin, fl
    pass side doesnt use one.
    That bracket strenghtens the parking brake assembly.
  28. tonkadawg
    tonkadawg
    great build!
    Is that a Chassis Engineering bolt in IFS?
  29. dirtydixon
    dirtydixon
  30. speters
    speters
    Thanks! Yes that is a Chassis Engineering bolt in IFS
