LETS CHOP A 39 FORD TRUCK CAB 100's of pics and vidios
Discussion in 'The Hokey Ass Message Board' started by Gambino_Kustoms, Apr 8, 2011.
  1. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    ok lets chop a 39 for truck cab 3'' strait down and with out leaning the a pillars back
    heres what we started with
    next we cleaned all the metal were we were gona cut and laid out our cut lines so
    lets get to cutin the first thing we did was remove the door tops
  2. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    we had 3 cut off wheels going so we were haulin ass we got to cutin on the a pillars and the back of the cab makin sure we left a tad bit of metal so every thing stayed a \tached until we were ready to remove the top
    we desided to remove the back window be cause there was some riot we need to fix on the bottom channel
  3. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    were getting real close to liftting the lid on this bitch
    ok now with the top off we can cut the metal were removing from the a pillars and the back of the cab
  4. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    ok we got all the metal we are removing for the chop
    heres a pic of every thing we choped of
  5. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    now lets set the top on to get a looky see
  6. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    a pic of every thing we cut off
    and one more of the top setting back on
    ok now its time to start making our releaf cuts on the a pillars i wanted to get the a pillars set and tacked be fore we moved to the back of the cab
    lets get a look
    EVL401 likes this.
  7. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    ok we got the a pillars all lined up corectly inside and out i wanted every thing lined back up on the a pillars perfectly so you couldnt tell or see were it was choped we didnt take as many pics as we should have of the whole a pillar prosess but you will see picks later on of the a pillars
    any ways with the a pillars lined up and tacked to gether we started laying out the cut lines for the back of the cab
    ok lets get to cuting the plan was to remove the the back of the cab in 2 pieces at the cab corners
    we had to re move an inner strucure
  8. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    ok lets get to double cutting this bitch
    time for a pit stop need a new wheel
    back in action
  9. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    man a whole lot o cuttin goin on
    were getting closer
  10. rusty bill
    rusty bill
  11. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    were almost there mad max i think he ot triger happy with the camera:D
    were getting real close now making our cuts on the inside of the door jamb
    real close now
    ok were there the driver side cab corner is off
  12. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    ok lets get the pass side cut off
    ok lets line things up for a little looky see
    heres what were gona have to fill in
    ok heres a pic with bolth corners gone before we cutem off we put in a suport to hold up the top
  13. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    heres some pics of the a pillars
    you can see the piece of drip rail we removed so we could weld every thing up nice like
    onother shot of the drip rail removed
  14. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    ok lets get the top preped so we can get this thing put back to gether
    heres the cab corners
    getting all the burs left from cutting cleaned off
    heres the corner clamped in place
  15. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    ok in these next shots youll be able to see what we did with these corners we moved the out a we bit and back!
    heres are lil prop we used to suport the top and hold it in place
    EVL401 likes this.
  16. k-member
    k-member
  17. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    ok now we can start making our relef cuts to the c pillars or cab corners
    lets get things clamped up and have a look
    a back shot
    lets get to tackin
    heres an inside shot of how we clamped the back of the cab that had a big gap
    we used round rod
    an inside look at things
    we were worried about the middle of the jambs sagging so we suported bolth sides with a bottle jack
  18. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    ok we got the cab corners lined up and tacked together in the jambs the plan was to start at the jambs and work our way to the back window
    now we can move around to the back window that aint there yet:D
    gota get every thing lined up just right
    we tacked in a few pieces of metal at the back of the cap above were the window will be just to hold things in place we will cut them out later
    ok lets move on to the pass side but first we need to hamer and dolly were a dent was we used heat then hammered the metal was stretched
    getting a better fit befor we tack it together
  19. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    ok now we can make some filler pieces for over the door jambs area on the top side of town
    drip rail included
    yes my neffu is a bad mother shut your mouth
  20. chrisntx
    chrisntx
    from Texas .
    I have been driving a 39 Ford pickup every day for 17 years. I pull a car hauler trailer thru four states on a regular basis. The cab is small and cramped. It doesnt seem like a good idea to make it smaller
  21. Muttley
    Muttley
    My old '39 had a ridiculous amount of headroom. I'm just under six feet tall and there was still a good two and a half feet above my head. I could have chopped that thing until there was no window at all and still had plenty of room in there. I dont see that chop being any problem unless the owner is eight feet tall.
  22. fleet-master
    fleet-master
    lookin good guys...gona chop my F-1 just the same way as your doin . Like how you've rounded the corners of your cuts ....just how i was taught.
  23. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    heres a couple of vidios not sure if the order is corect
    <iframe title="YouTube video player" width="480" height="390" src="http://www.youtube.com/embed/jI0d_QciWTo" frameborder="0" allowfullscreen></iframe>
    <iframe title="YouTube video player" width="480" height="390" src="http://www.youtube.com/embed/uComHUprOQM" frameborder="0" allowfullscreen></iframe>
    <iframe title="YouTube video player" width="480" height="390" src="http://www.youtube.com/embed/Ume2psaEsMk" frameborder="0" allowfullscreen></iframe>
  24. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    thanxs please do
    thanxs
  25. n.z.rodder
    n.z.rodder
    Subscribed, I gotta finish the chop on mine sometime (bought it half done).
    Scotty.
  26. thanks for postig this, its good to see somethig being done by a pro and step by step so if i were doin it i could follow along and have less chance of f**king it up (i say less chance coz i can f**k anything up:D:eek:). il hafta buy a closed car oneday then il use this thread to chop it. thanks again
  27. floydjer
    floydjer
    Great tutorial..........Once you translate it into English.:cool:
  28. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    :confused::confused::confused::confused::confused::confused:
  29. Terry
    Terry
    Fun to watch a pro at work! Thanks for taking the time to bring us along.
  30. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    ok were doing this truck chop for pops29 here on the hamb heres a rendering he had done of what the trucks gona look like
    pops29's plan is building a 1939 Ford PU. With a few mods. The concept drawing is by E Black design. his plans are a 3" chop, dropping the stock Grille assembly and blending in a 36 passenger grille and partial hood with louvers , I will be running a Buick 322 nailhead with 6 97's.
    thank you vary much
