Projects A Model Sport Coupe
Discussion in 'The Hokey Ass Message Board' started by OoltewahSpeedShop, Sep 13, 2008.
  1. OoltewahSpeedShop
    OoltewahSpeedShop
    Gotta see more pics of this car. Who's got them?
  2. The37Kid
    The37Kid
    Is the current owner a HAMB member?:confused:
  3. RandyatBBY
    RandyatBBY
    Hear is a shot of a original sport coupe in the 60ties.
    Uploaded with ImageShack.us
  4. 41 Dave
    41 Dave
    Kev, Got to agree that Joe McClelland's Sports Coupe is the way to GO ! Just the right profile and stance. Seems to fit your idea of a sport coupe. Just add the right little changes to make it yours.
    Dave
  5. OoltewahSpeedShop
    OoltewahSpeedShop
    We had a our Banger running on the stand... It sprung a leak. Found a few cracks in the head. As it turns out.... Good A model heads are hard to find. Luckily my buddy Mike had a real nice one listed right here on the Hamb.
    We should be hearing that clucking Banger sound again real soon. This time with no water in the oil issues.... We hope.
  6. OoltewahSpeedShop
    OoltewahSpeedShop
    The new Banger is done. I got the Sporty out of Hibernation last night and looks like we will driving before long. I pulled the body off so we can install the new engine and trans. I'm going with hyd brakes, So Cal dropped axle, and '34 wires with Coker blackwall Big's and Little's.
    Here's a few pics of the progress....
  7. Royalshifter
    Royalshifter
    Moderator
    Looking cool man.
  8. 42 chevy
    42 chevy
    Very cool thread.
  9. OoltewahSpeedShop
    OoltewahSpeedShop
    Got some more work done tonight. Drilled the new SoCal 4" dropped axle with (21) 1" holes. I used a Milwaukee Magnetic Slugger drill. This is by far the best tool for this job. Drills a perfect hole and only took about an hour from start to finish. After a little de-burring it should be ready for paint or chrome. The SoCal axle is a killer piece. The quality is the best I've seen.
    Here's a few pics....
  10. 41 Dave
    41 Dave
    Kev, Love the look of a droppedand drilled axle ! Sure will be some great eye candy for your Sport Coupe ! Wow, check it out ! This is #41 response for this thread. Love that number !
    Dave
  11. OoltewahSpeedShop
    OoltewahSpeedShop
    Thanks guys.... Any clues or tricks on converting the stock A model rearend to '40 hyd brakes?
  12. OoltewahSpeedShop
    OoltewahSpeedShop
    I've been stripping a '40 Ford frontend this morning for the brakes and wishbones. Everything was going JUST FINE.... Then the perch bolts. Damn they are stuck. Here's a few pictures.
    Any tricks to getting these damn perch bolts out?
  13. DeepSea Fish
    DeepSea Fish
    Oh man, this car is going to be cool. I love the plans and the axle looks awesome. Tell me more about that contraption you used to drill it with, never seen anything like that before. So is it getting a 4cyl. engine or a V8?
    Did you use some heat from a torch on the frozen bolts? That might free them up. You said something about wire wheels? Lets see your plans on that.
    Keep up the good work. Glad to see you working on this one again.
  14. OoltewahSpeedShop
    OoltewahSpeedShop
    The drill is a Milwaukee magnetic base drill that uses a broach type bit similar to an end mill. It has a spring loaded center pin to line everything up with your punch mark. It's intended use is for steel fabrication, for column base plates. We use it in the electrical field for all kinds of different things. It also works great on Hot rod stuff. ;)
    It is getting a souped up 4 banger instead of the originally planned V8.
    I'm going to put some heat on the frontend parts in the morning. After a couple of bloody knuckles from the hammer and chizzle... I'm done beating on it.
    Stay tuned for more updates coming soon.
  15. Awesome car, looks like truck loads of fun.
  16. OoltewahSpeedShop
    OoltewahSpeedShop
    Same basic tire and wheel set-up as the first two cars. These are 16's and mine are 17's, but that's the only difference. The last picture is of my tires, but mounted on Chevy artillery wheels. Swap them to '34 wires and that's the plan... What do you guy's think?
  17. pug man
    pug man
    from louisiana
    Love the wheels and the tires to. Gonna be very cool..... subscibed......
  18. OoltewahSpeedShop
    OoltewahSpeedShop
    Do you have to run some sort of adapter plates behind wire wheels on '40 drums?
  19. 48 Chubby
    48 Chubby
    Yep. Vern Tardel and some others sell em.
  20. OoltewahSpeedShop
    OoltewahSpeedShop
    Did some research.... Seems like the wires need some support that the hydraulic drums don't provide. The receiver ring that the wires mount to is wider than the '39 and up drum mounting surface. It's hard to fathom, but seems like Henry didn't think about us Hot Rodders on that one. Good thing we have Vern and Speedy Bill.
  21. Lucky444
    Lucky444
    4 Banger with 17" Wires? Sounds like you're doing this one up just right!
    The Sport Coupe is such an odd ball mobile, it'll be such a cool and unusual Rod. Nice.
  22. BCCHOPIT
    BCCHOPIT
    Glad to see you are keeping the banger. I wish the mag drill we have at work had the support on the bottom like the one you are using. I don't think the shops drill would live very long using the big bits like that with out the support
  23. OoltewahSpeedShop
    OoltewahSpeedShop
    Now... If I just had one of your intake/header flange set-ups, I'd be ready.
  24. BCCHOPIT
    BCCHOPIT
    I have a real cool look-in header in my head I hope to have one or two done in 2-3 weeks I will pm some pics when I am done.
  25. OoltewahSpeedShop
    OoltewahSpeedShop
    Can't wait to see it... Maybe we can "Test" it on the Sporty...? :D
  26. 41 Dave
    41 Dave
    Man, Now this is goin' to be one Neat Hot Rod - Sport Cope ! Need to work one of these into my inventory . . . . .
    Dave
  27. Smoking
    Smoking
    from Florida
    The Coupe is to cool! Fire it up and lets ride!
    Nice find!
    Smoking
  28. 29ToyA
    29ToyA
    Great project!
  29. OoltewahSpeedShop
    OoltewahSpeedShop
    I've always been a Sport Coupe nut, mainly because you just never see them Hot Rodded right. Most people just yank all the top stuff that makes them so different and cool. They look great chopped too.
    Thanks Dave...
    We are trying.... I'm ready to ride this one around.
  30. OoltewahSpeedShop
    OoltewahSpeedShop
    Thanks...
