Free step notch for 47-54 chevy truck
Discussion in 'The Hokey Ass Message Board' started by cain, Mar 17, 2011.
  1. cain
    cain
    from riverside
    We at Jimenez Bros Customs are giving away a free step notch kit for chevy truck 1947-54 , Please submit photos we will pick truck as soon as we get 25 photos to choose from.
    recipient responsible for shipping and handling
    thank you
    JIMENEZ BROS CUSTOMS
  2. stinkity stoink
    stinkity stoink
    from new jersey
    wow . this was a few pages back allready. i will bump it for those that need it. I will put mine up later
  3. 65PANELRAT
    65PANELRAT
    My ol' 54' lowered the "Poor Man Way" with leaf spring removal.
  4. :D PICK ME, PICK ME :D
  5. bretcopsey
    bretcopsey
    from DAYTON, OH
    I'm throwin in my hat. Here's when it came home and about where I'm at so far...
  6. Chevy54
    Chevy54
    from Orange, CA
    Great giveaway guys! My new project..getting ready to be torn down!
  7. dirtydixon
    dirtydixon
  8. Mr48chev
    Boy Howdy you are a mind reader.
    I just moved my frame around in front of my garage last weekend to get started installing the front cross member and was pondering what to do for the step notch in the back. I am running leaf springs in the back an don't need a huge notch so that would be perfect.
    As it sits today. The wheels are getting changed for steelies and white walls.
    As low as I can get the back end now as there is one inch of clearance over the axle.
  9. skip99
    skip99
    from ohio
    51 , chopped, MII front, leaf rear...so far... converted window to 1 pc. ,53 door handles with bearclaws, ton's of smoothing...
  10. I have 2, here is the one in the shop right now,
  11. Danimal
    Danimal
    1. A-D Truckers
    Help a brother get down from the nose bleed seats. 1 tons sit 18 1/2" from the rockers to the ground. Scott Danforth kit going in up front and an RBs for the rear but it just won't be low enough. Even with a BBC/TH440!
  12. Camaro Mike
    Camaro Mike
    My 48, just waiting to have some cool applied.
  13. butcherted
    butcherted
    from hagerstown
    Here is my 50 Gmc suburban it need to be low and slow.
  14. Atomsplitter
    Atomsplitter
    1948 Canadian Chevy.
    I'm just about to buy a bed and this would be perfect timing!
  15. melsfine39
    melsfine39
    IF ITS FREE! ITS FOR ME! I need all and any help I can get!. Starting on the chassis now.This would be a very welcome part. The chassis that came with the truck was JUNK!(see photos) I found a replacement and a S10 rear. I also have a dropped axle for the front and a mounting kit for the rear(new springs & mounts, shock mounts,ect...) , but need to get it down lower to work with the front drop. I am further along with the chassis than the pictures show and I had planned to do this anyway, but this would save me some money for other things and move me ahead greatly!. Thanks Mel:D
      124.9 KB
      369.2 KB
      385.7 KB
      119.4 KB
      94.6 KB
  16. orula
    orula
  17. droplord49
    droplord49
    from Bryan, Tx
    Count me in! I am just about ready to start hacking on my truck and that notch would look nice on it.
  18. here is mine. the bed is off and being rebuilt. I will hold off on the bed till this is over.
  19. adamshumard
    adamshumard
    Here's mine. Putting a 54 car ifs on it with dropped uprights., s10 t5, s10 rear. Then a set of genie caps and rings. Putting her on the ground.
  20. Danimal
    Danimal
    1. A-D Truckers
    Adam,
    Watch the S10 rear end if you don't intend to tub. The 4x2 is too narrow and the 4x4 is not right either depending on wheel offset. If you have the ZR2 you should be OK.
  21. adamshumard
    adamshumard
    I had heard that the 4X4 was a good option. I will be ordering the wheels so I will have to get the offset right. Whats wrong with the 4x4 rear?
  22. low springs
    low springs
    from Long Beach
    Great idea Cain. is your brother pulling his own weight? hahah the notch looks cool.
    Dante
  23. Chevy54
    Chevy54
    from Orange, CA
    Dante....man, you know everyone bro!! hah
  24. adamshumard
    adamshumard
    Heres a larger shot
  25. adamshumard
    adamshumard
    with this kit, what modifications are required to the bed floor?
  26. last g-man
    last g-man
    .....'54's probably ok but the '49 could certainly benefit.
  27. Big Earl
    Big Earl
    I could use it on my '50 or...
    ...or my 48
  28. Ctm_motortrends
    Ctm_motortrends
    from Ontario Ca
    Here's mind it's a 49 now 5 window and heres what the frame looks like right now.
  29. RDO_23
    RDO_23
    I'm in!
    my 52 has the stock frame under it
  30. dt50chev
    dt50chev
    Mine's on an S-10 frame and I have plenty of room to put the running boards on the ground if I want to. No need for the step notch but thank you for providing it tor the lucky winner.
