Can any one tell me if this is correct. + side of battery to starter and to fuse block and to bat terminal on key switch. Start terminal of key switch to start solinoid on starter.hot wire goes from fuse block to fire wall resistor them to + side if distributor That is as far as I can get . Any one have a simple wire diagram they can share.
