The plan is to make it look like some one built in 1959 ish. So I have a 283, 3 speed, 40 banjo rear, 38 front axle with 40 brakes. Trying to disturb as little of the original paint as possible The bed side is just set up there for the pic and these are not the wheels I am running. Planning 16" steels with 5.5 up front and 7.5 out back Has a long wheel base but it won't look as goofy with the with the 16x7.5 out back a back view with the bed sides leaned up for the picture I am pleased with how the chop turned out a picture of the rear spring mount that i made to look like something that Ford put out. The rear end I am using had the stock spring perches cut off
