55 Chevy gasser....Fab pics.
Discussion in 'The Hokey Ass Message Board' started by Kiwi Kev, Nov 10, 2006.
  1. ssffnomad
    ssffnomad
    Nice car wish i kept my No Mad
    Yep, That,s Cool, back when Cars had Rubber
  2. CalGasser
    CalGasser
    My sentiments!!! :)
  3. ricky from va
    ricky from va
    kiwi kev I dont say much but i will now . your fab work looks all most flawless. pro all the way.
  4. 55chieftain
    55chieftain
    You guys did an awesome job. 55 Chevy gassers are one of my favorites. I'm into Pontiacs thats why i'm building a Pontiac version gasser. This thread should go in the tech archive.
  5. Vic,
    If you bring it to the Ventura Nats,don't forget to un-cork it!!!!!!!! Announce your interance,haha!
  6. uwonamos
    uwonamos
    from Omaha, Ne
    Hey Vic, thought the car deserved bigger pics.:cool: That thing looks so RAW & MEAN. I LOVE it.:D
    One other thing?? You going to leave the lower grill valence off ?? Oh, and can I borrow your tires & wheels for the World of Wheels here next week!!:eek::rolleyes::D Dan
  7. DamnYankeesKustoms
    DamnYankeesKustoms
  8. Looking good Vic. Nice to see some progress. Looks a lot different now....
  9. CalGasser
    CalGasser
    Hey Dan, you made the pix too large - now everyone can see the flaws...:eek::D Yes, I'm leaving the lower valence off to give it that MEAN look.;) No problem with loan on the wheels - just sign over your mortgage and your first born... ha ha :D Vic
  10. CalGasser
    CalGasser
    Hey Bob, not a problem - you mean like my Willys? :D This car will NOT have an exhaust system (or I don't plan on it anyway). I will insert a set of baffles in the collector and go with just that for muffling - unless Johnny Law has other plans for me. Wish me luck! Vic
  11. Cut55
    Cut55
    from WA
    That's so cool I just pissed my shorts... I can just see it: 396, M-21, 4.11s. Oh, and stock manual drum brakes!
  12. Cut55
    Cut55
    from WA
    A blower would make this car perfect. Anything less would not be enough--except maybe a period Hilborn setup. I'd love to put an unpolished huffer on my '55.
  13. trey2618
    trey2618
    from Cisco
    nice work, I am going to run my car one last time May 14 at Yello Belly then take the sawzall to the stock front suspension, I have my axle rebuilt and gathering remainder of parts. I noticed your frame work, I have seen alot with 2x4 and 3x4, this looks like 3x5, I like the way it matches stock frame. Is this correct and any advise on this, Thanks Trey
  14. CalGasser
    CalGasser
    Cut55: I have an unpolished 6:71 for the car but $$$ will dictate when it'll happen.
    Trey: Frame is 2x4 tubing. I think wall thickness is 1/8". Maybe Kiwi Kev can chime in? Good luck on your project. Vic
  15. Vic got it right.
  16. AHotRod
    AHotRod
    Looks killer Kev !
  17. GassersGarage
    GassersGarage
    Any updates on that bad boy??????????
  18. Kevin is doing the axle on my car now. There will be a build thread soon. If you can go to the Beatnik Blowout this weekend my car will be in Kevins garage still getting the finishing touches.
  19. need louvers ?
    need louvers ?
    Cool! just spent a bit searching this thread up again 'cause Hot Rod Ron and I were bench racing a '55 Chev straight axle car this weekend at the South West Nostalgia Nats... Let's see... Found a body, Check, frame, check, Buildable 350 core in the yard, Check, set of Americans & Hurst recaps, check, front end, check... What could possibly go wrong?!?! Never mind, I know...
  20. Nice
  21. 69fury
    69fury
    Top notch, as always- i may have to steal the expanded mesh hood mount idea if I ever do a tilter- clever and simple.
    I dont understand the leaf floaters, however. I've never seen the rollers on the sides of the leafpack- how is the friction against the top/bottom straps going to be dealt with?
    rick
  22. I cannot get the clown with body too call me back so we can go see it and see if its buildable. gonna keep trying. Love this build and the car is real mean looking. I would do nothing else to it but get it running. I say leave the trim off.
  23. CalGasser
    CalGasser
    Those are not rollers on the side of the leaves. They're spacers so the top and bottom plate don't tighten down on the spring when secured to allow the floater unit to slide. I installed a thin piece of teflon on the bottom so the floater will slide easier. I don't remember (CRS) what clearance I used but it's not much - just enough so the unit will slide on the sping and not rattle and clank.
    There will be trim on the car but not to worry, it'll still look MEAN! :D
    Vic
  24. 69fury
    69fury
    Ah- that makes perfect sense. Never thought of teflon instead of rollers-pretty sharp.
    Is durability going to be a concern with the teflon strip? I've never liked the roller style when real bearings aren't used (talking street driven applications, here)
    -rick
  25. With those floaters the weight of the car is supported by the pivot bolt so there is no heavy duty friction between floater and leaf spring.
  26. CalGasser
    CalGasser
    I put teflon more to prevent metal to metal contact. I feel teflon should help with less friction. Like Kev said, load will be on the pivot bolt.
  27. CalGasser
    CalGasser
    Thought I'd put a pulse back into this 55 Gasser build as it's been awhile since posting anything. Had the car lettered & rearend built but that's about it. Will start on it again. Enjoy the pix...:p
  28. CalGasser
    CalGasser
    Oops, forgot to acknowledge some important people...:)
      294.1 KB
  29. ntxcustoms
    ntxcustoms
    from dfw
    Looking sharp! Most badass...
