54 chevy question
Discussion in 'The Hokey Ass Message Board' started by Mike662, Feb 14, 2011.
  1. Mike662
    Mike662
    Been driving my 54 chevy for a couple of years and havent touched the motor since i got it. Runs great so why screw with it if it aint broke. The only problem Im trying to address this year is after driving longer distances if you go to start it right after shutting off, motor turns over way too slow, and then sometimes catches and turns over normally. Ive got the origanl 115 6 cylinder in there. Any opions as to if its the timing, or maybe the selinoid?
  2. RDR
    RDR
    is it still 6 volts?...need a bit more info...does it seem to "kick" against the starter (timing) when you say it turns over slowly or does it just sound like a low battery?....could be the starter armature dragging on the windings (worn bushings)
  3. Mike662
    Mike662
    yes still 6 volt, turns slow like low battery
  4. kustom beale
    kustom beale
    from ladner b.c
    my 6 volt ford generator was worn down ,car would still start ,but cranked slow.check how much yours is chargeing should be 7+ volts.rock on
  5. 53sled
    53sled
    from KCMO
    Cheap things first, throw a new heavy ground cable on. Then a new Positive cable.
  6. JohnEvans
    JohnEvans
    from Phoenix AZ
    Draging starter would be the place I would look . That is a problem that shows up when things are hot first, later all the time.
  7. jcmarz
    jcmarz
    from Chino, Ca
    I had no idea that Chevy made a 115-6 cylinder!
  8. DIRTY_WHITE_BOY
    DIRTY_WHITE_BOY
    from Tennessee
    When fuel went up to 27 cents a gallon Chevrolet went to a 3 cylinder 115 cubic inch to save fuel. It still had the same starter as the 235 though.
  9. PhilJohnson
    PhilJohnson
    I need to find me one of them 3 cylinders. Sure would be great to save some coin at the pump :D
  10. Mike662
    Mike662
    Stock Motor Blue Flame 115
  11. 53sled
    53sled
    from KCMO
    Yeah, well, we call them Stovebolts or 235s. but i digress.
  12. johnny bondo
    johnny bondo
    from illinois
    i think thats the smaller model 216.
  13. JohnEvans
    JohnEvans
    from Phoenix AZ
    Nope that's a 235 !
  14. 53sled
    53sled
    from KCMO
  15. Mr48chev
    I'd go along with the armature dragging. You can pick up brushes and bushings at NAPA and or some other parts houses and rebuild/refresh the starter in about an hour or so including pulling it off and putting it back on.
    The brushes would either be these
    http://www.napaonline.com/Search/Detail.aspx?A=ECHR503_0314524905&An=599001+101954+50012+2012017
    or these
    http://www.napaonline.com/Search/Detail.aspx?A=ECHR500_0059079073&An=599001+101954+50012+2012017
    depending on the shape of the ones you have and the bushings would be these
    http://www.napaonline.com/Search/Detail.aspx?A=ECH4200_0059078621&An=599001+101954+50012+2012017
    and
    Obviously you have to take the starter apart. The brushes are pretty self explanatory and it takes a small sharp chisel ( I use an old screwdriver that I have sharpened) to cut and crimp the old bushing in so that you can pull it out with needle nose plyers. Drive the new bushings in and put a little bit of lube on them and put it back together good for another few years.
  16. Mike662
    Mike662
    thanx for all the info!
  17. Straight Eight
    Straight Eight
    from Howell, Mi
    Might be the field coils. I had the same symptoms. New field coils fixed it
  18. wvenfield
    wvenfield
    My 1954 Chevy with the 235 did the same thing. I was told to check all the stuff you were told and then I was told to do this..............
    After a long drive when the car got hot and the car would barely turn over I was told to pore some cold water over the starter. If it then starts right up it's time to rebuild the starter.
    Sounds silly, but mine was as simple as that.
  19. 32phil
    32phil
    from New York
    My Dad had a 54 Chevy, he bought it new. It was his first new car. I remember going to the Dealer, Pape Chevrolet in the Bronx, NYC to pick it up. Pretty car it was a Two Ten 2 door sedan , white top over dark blue body. He kept it 9 years. Once it was about 6 years old it wouldn't start when hot. We never figured out why. From what everyone is saying it probably needed a new starter.
