Rust removal.......the miracle of molasses!
Discussion in 'The Hokey Ass Message Board' started by evintho, Feb 5, 2011.
  1. evintho
    evintho
    Yeah it does work!
    After a couple of weeks in a molasses bath.............
    You'll notice rust on the lower 6" or so. That's because the first time I tried it, my pond liner had a leak and most of the molasses drained out. So, I left it in and it dissolved the rust on the first 6". Got a new liner and flipped the panels over. The rusty part was originally clean but stuck out and was exposed to air. It's only surface rust that'll come off with a light sandblasting (as will the flash rust that begins forming almost immediately).
    First run with the doors (notice no harm to original paint, rubber or pot metal).............
    Built a 4'x4' box out of scrap 2x4's and OSB.............
    Installed a reclaimed pond liner from an old pond in our backyard...............
    Proof positive that an entire '27 Model T roadster will fit in a 4'x4' box..........
    20 gallons of molasses bought at a local feed store for $60 including tax, then mixed with water at a 7:1 ratio - 7 parts water to 1 part molasses............
    Entire car submerged in the brew (until most of it leaked out)!.............
    Replaced the liner, added some more molasses and after a few weeks............wah lah!
  2. MODELA30
    MODELA30
    Very cool thanks for the ratio info!!!! Knuck from indiana.
  3. budd
    budd
    thanks, around here i see alot of free hot tubs on craigslist, heat and a circulating pump.
  4. modeleh
    modeleh
  5. WOW! I am impressed - looks great!
  6. 117harv
    117harv
    Yes, great idea making the box, thanks for posting. Thats much easier than digging a hole in the back yard. I have heard from severall people that heating up the solution to say 80 or 90 degrees speeds up the process 10 fold.
  7. Zombie Duck
    Zombie Duck
    I'll have to try that on my T body, thanks for the info!
  8. havi
    havi
    Nice! I've done vinegar for smaller stuff, and this Summer I'll be doing big stuff in molasses. (Wanted to do it this Winter, but felt the water mix would freeze) It's great to see another success story. Deer around here smell that molasses and they come double-quick. So if there's animals in the area, make sure they can't get to it.
  9. PipeWelder81
    PipeWelder81
    wow thats impressive, i didnt know you could use molasses. Im going to have to give that a shot sometime, thanks for the post!
  10. ginuine555
    ginuine555
    from louisiana
    Great job. I used it to clean up some bolts and tools a while back after hearing about. Reall works well.
  11. mikeey rat
    mikeey rat
    from Australia
    It;s just like extra strong sugar soap.iT EATS SOME THINGS THOUGH ;I did some bike chains I probably left em in too long[months] all i found was a bunch of little figure eights in the bottom of the tub the rest was gone really stinks too .dont think you could do it in a residential area.we also used it to free a stuck flathead. taking the part out every day or two and washing the black stuff off speeds the process too.totally safe to use too GOOD SHIT
  12. mikeey rat
    mikeey rat
    from Australia
    de grease first otherwise it weakens the mixture
  13. oldgoaly
    oldgoaly
    For small parts a "crock pot" used one is fine, would not recommend using for food after using it for molasses. Small stuff is much easier to find in the crock pot that bottom of the barrel....tt
  14. Remember the kids science project with the metal left in a glass of Coke, I guess it's the same principal, with a diluted mixture.
    Sweet solution to a rusty problem!...oh I'm killing it here...thanks very much folks, I'll be here all week, try the prime rib and dont forget to tip you waitress...
    www.highspeddmotorsports.com
  15. Duce of Diamonds
    Duce of Diamonds
    from NW IOWA
    what is the mixture??????????
  16. hellsgaterods
    hellsgaterods
    thats crazy neat! never heard of it before, i love this place!!
  17. Hellbomb
    Hellbomb
    from DC
    How does the car taste?
  18. hellsgaterods
    hellsgaterods
    started my own molasses experiment this past weekend, ill let you know how it turns out.
  19. shainerman
    shainerman
    I laughed out loud about this for some reason. Thanks, haha
  20. Yeah....molasses is nice...but I'd rather soak it in cider:D
  21. squirrel
    sweet!!!
  22. HA I am building a 'tank' today to soak my parts in.
  23. henry's57bbwagon
    henry's57bbwagon
    Called my local farm supply and he has feed grade molasses in 20Ltr pails for 12.50, less when paying cash.
  24. Incredible results!
  25. chopped
    chopped
    Anyone know if you can use powered and make regular molasses from it. I know a guy with a bunch of dry.
  26. I know a guy that soaks complete flatheads that are stuck. Works great. Just don't use it to make cookies later
  27. ArtGeco
    ArtGeco
    from Miami
    Will it break down oil and grease, or just rust?
  28. 117harv
    117harv
    No oil, grease or paint, however some paint may come off if the bond is bad and there is rust under it.
  29. Cheers for all the info,will try it soon on my RPU's bed.JW[​IMG]
  30. A Boner
    A Boner
    Do the parts need to be rinsed to neutralize the mixture? Does it leach out from double layer panels at a later date......can it screw up a paint job?
