I just found a dodge super red ram Hemi (D553) so its a 270! The only issue I know of is that its missing the crankshaft. Been looking around and just cant find any info on a crankshaft replacements! Does any one have any info? Thanks
241,259 and 270 should all be the same. A poly crank would work also. Put an ad on HotHeads and also our classified swap.
I haven't purchased the little guy "yet"! I kinda depends on crankshaft availably and cost! I think it would be fun if a bigger ci. crankshaft would fit and make a little stroker! I really don't have a use for it yet! I just think it would be s cool one to have.
If you need more inches then start with a bigger engine. If you have money to toss around you can buy/make a welded stroker but keep in mind you only have a 3.625 bore. .
Not lookin for a lot of HP out of it! Just wanted to know what and if it was worth messing it? I have no plans for it! I might just pick it up and part it out/re-sale it!
I've got an extra 241 crank I'd take $75 needs at least polished maybe turned surface rust now .10 .10
