Eddie's 31 A
Discussion in 'The Hokey Ass Message Board' started by Eddie's chop shop, Jan 4, 2007.
  1. That is one bad ass ride. I love the work you are doing. Keep it up!
  2. Skimmer
    Skimmer
    Good thread ...........Informative ...
  3. I know its been a while but I read every page today, great project!
    I'm wondering what you used for the hard line piping for the radiator? I have a project with the radiator going in the trunk and was looking for ideas on what type of hard line to use.
    Thanks
  4. model-a-fan
    model-a-fan
    from Kentucky
    Very well built. I noticed you didn't brace the body when you cut the floor out. Is this commonplace? I was under the impression that you had to brace. I'm not going to waste my time on mine if it isn't really needed.
  5. I would brace it before I cut it.
  6. Eddie's chop shop
    Eddie's chop shop
    Kailuaz, I used 1 3/4 tubing. 3 sections with rubber joints. Works well also has the added advantage of holding alot of coolant. I've seen guys running small lines and have wondered how that works, but they were also running basic small blocks.
  7. Eddie's chop shop
    Eddie's chop shop
    You really should brace it. I kept the door sills which kept the spacing right, but the b-pillars could move in our out and cause some alignment issues if not in the right place when the new floor goes in. However it is not a big deal to have the doors hanging on it and use the doors to make sure everything is where it should be. Good luck.
  8. Eddie's chop shop
    Eddie's chop shop
    Haven't worked on the car much lately. Come spring it will get a new tranny adn some real slicks to see what it will do at the track. I am still working on teh leather roof.
    Had a photo shoot in So-Cal Sac shop last weekend and it will probably get some magazine coverage soon. I'll keep yah posted.
  9. Eddie's chop shop
    Eddie's chop shop
    here's some new shots
  10. Eddie's chop shop
    Eddie's chop shop
    finally got my tig for home!
  11. burninbilly
    burninbilly
    Littleman sweet build,,,, we wanna see some smoke pouring from those tires
  12. Thanks for the info, much appreciated.
  13. jrebz
    jrebz
    Awesome work man, love the build!
  14. Eddie's chop shop
    Eddie's chop shop
    In case you guys missed my thread on teh injection. Here it is on the car
  15. langy
    langy
    I havn't looked in on this build for a while but its a great thread, Eddie car looks great. next time i'm in NorCal i must try and pop by.
  16. holeshot
    holeshot
    from Waxahachie
    EDDIE...quite simply, YOUR THE MAN. that's the best coupe on H.A.M.B. nothing else even come's close. and that's a fact. i fell very strongly you should name your old huppy-THE KING COUPE- and you can take all that shit talk too the DO-DO bank...POP.
  17. Hot Rod Michelle
    Hot Rod Michelle
    Looking pretty cool. Not my particular taste, a little too low, but, pretty cool nevertheless.
  18. Eddie's chop shop
    Eddie's chop shop
  19. Eddie's chop shop
    Eddie's chop shop
    Kinda broke the block about a month ago. Oops...!
    So just drove it again today. Its now 520CI new cam and the injection. Safe to say I finally have enough power. Now just needs more tire on it.
    This thing is starting to get NASTY!
  20. Eddie's chop shop
    Eddie's chop shop
    Been awhile since I posted in this so.. Car's running great!
  21. Motorbreath
    Motorbreath
    Man this thing is like a metal orgasm....... take that how you must
  22. crotex
    crotex
    from cuero, tx
    what a badass car...I wish I had the time/money to do that with mine. Nice work man.
  23. Untame
    Untame
    Insane. Way over the top (or "under the bottom"). Congrats.
    Untame
  24. Eddie's chop shop
    Eddie's chop shop
    Hey, thanks again for the compliments. I love this last photo it looks sooooo hot wheels.
  25. MIKE-3137
    MIKE-3137
    How about a shot from the drivers seat? That thing is bad to the bone, I bet you can't see much out of the right front!
  26. harald
    harald
    Awesome coupe,I dont care what style it is or isnt,dont really know why so many people are so obsessed with trying to name everything.All that matters is that it looks cool ,is fast and sounds awesome and you build it .Thats what hot rodding is all about.
    And for those guys with their negative comments-get a life .
  27. Eddie's chop shop
    Eddie's chop shop
    I've never taken one, I will have to do that. Its not as bad as it looks though.
  28. mosimpson
    mosimpson
    Eddie-
    I was checking out your brake set-up in this photo. Do the sst. lines terminate at some bulkhead inside the car body? Do they run all the way out to the frame? Do you ever take the body on and off the chassis and have some suggestions on how the brake lines should be set-up with a hanging pedal assembly?
  29. Eddie's chop shop
    Eddie's chop shop
    Mine simply go through a hole in the floor to attach to the hard lines on the frame. No the body doesn't come off on a regular basis. YOu could buy hydraulic fittings that work like the ones on a porta power (kinda quick release like air fittings) that would allow quick connect/disconnect without having to worry about bleading etc.
  30. farmer12
    farmer12
    Wow! Can't believe I just found this thread. Absolutely amazing work. Congrats!
