removing powder coating?
Discussion in 'The Hokey Ass Message Board' started by srdart67, Jan 8, 2011.
  1. srdart67
    srdart67
    from Sharon, Wi
    I took some parts off an old stove to use as sheet metal and they are powder coated. I have tried grinding it off with 36 grit tried using a sander with 80 grit and tried sandblasting it and heating it. sandblaster worked the best but i dont feel like using 50lbs of sand to clean off a 2inch wide 10 inch long area.
    Any ideas or input on a strategy that works well timely and efficiently?
  2. Oxy/Ace torch works well. Heat that bugger up and it pops off. Mikey
  3. Ryan272
    Ryan272
    from Australia
  4. 1971BB427
    1971BB427
    from Oregon
    Powder coater told me it gets soft when heated, so just heat it and scrape it while it's soft and sticky.
  5. john worden
    john worden
    from iowa
    I suggest that if you want "timely and efficiently" buy a small piece of new steel from Menards. :D
  6. Depends how old it is, it may be porcelain.
  7. THE_DUDE
    THE_DUDE
    I blew some off with breakleen
  8. racer756
    racer756
    Thats what I was gunna say. It shouldnt be that hard to take powder coating off..
  9. matts37chev
    matts37chev
  10. Mr48chev
    Yep, most likely it is porcelain covered.
  11. Ditto!
  12. pdq67
    pdq67
    I figure if you can even buy it, that Methylene Chloride, (aka, MC), will remove it.
    Just put it in a metal or polyethylene pan and let it soak.
    Otherwise if this doesn't peal it, burn it off.
    Also Berrymann's #12 carb cleaner with the parts basket should do the same thing because the other 49 states product they sell contains MC and Cresol covered with like a 1/4" of water to hold evaporated voc air pollution emissions down.
    And B's #12 will peal the skin off your hands so watch it!! Just ask me how I know.......
    pdq67
  13. srdart67
    srdart67
    from Sharon, Wi
    I quit i tried aircraft stripper and then a torch and warped the hell out of it. must be porcelain. goin to get some new stock. for future reference how does one remove the porcelain finish?
