Trying to save this '29 Chevy fuel sending unit but the float is "gass" logged and reads empty. Can I dry it and seal it with gas tank sealer or what? If replacing with a plastic float what epoxy if any will hold up to being submerged in gas? Thanks
That's funny guys but to early to hit the wine, seems it would be to small anyway. I built a '29 Ford for a guy (his first car) back when and he put it on one of his wine labels.
Why does it have to be cork? I'd check for a similar sized brass float from just about anything and solder it to the rod. As long as the distance from the pivot is right and it floats, what else matters?
Good idea but was worried that if it rubs on bottom (empty) or top of tank (full) it wouldn't last as long as cork or plastic, dunno.......................
you can usually get corks at the hardware store, as to a sealer for it, not sure. Not too many finishes like gasoline, especially with the ethanol in them...might just have to leave it bare and see how long the natural cork takes to break down or absorb enogh gas to sink...I think they naturally resist chemicals for a long time. you could always mix some epoxy and ball it up on the end of a toothpick before dries and then soak it in gas to see if it is resistant, if so coat the cork in epoxy...
you can order a fuel gaugefloat from Mac`s for A model they have 2 types cork or neoprene one is $1.50 the other is $4.65 they will work.
i always thought that shellac was used originally to seal cork gas gauge floats, but with ethanol fuel i'm not sure if it would hold up i'm sure this one from Snyder's could be adapted http://www.snydersantiqueauto.com/2450
I've used corks from the hardware store, they have them in a wide variety of sizes. Trim and sand to shape, mount on the float rod, then dip the whole thing in Red-Kote gas tank liner and they work beautifully. Red Kote info: http://damonq.com/files/Red-Kote.pdf
Maybe they have it figured out by now but I have nightmares about the plastic floats in the Quadrajets back when. I just remember having to buy scales to weigh the plastic floats to see if they were too heavy from absorbing fuel to use on a rebuild. I'm just leery of plastic floats. Maybe I'm just paranoid.
I run the stock float on my A...When i went through the car i decided to replace the float with a new cork one, well to my suprise the coating on the cork turned to concrete and sunk the float to the bottom!! the suspect, you guessed it, ethanol gas!!...Replaced it with the poly one(its like a cylinder of hard foam) and no further problems.
