Hey guys! Anyone running a 6x2 intake as straight or progressive linkage AND running chokes?? Would really like to see how you handled the linkage and what not for the chokes. Specifically interested in Holley 94 setups, but Stroms would be similar, so that's okay too... Probably rarely used and for a reason, but just curious for those who have. Thanks!
PM Uncle Max for the straight scoop, but I've heard the experts say that carbs like the choke plates left in place whether they are ever closed off or not. Helps to direct the flow more than the removed plate would lessen a hinder. Clear? (Leave them all in but only hook up the middle for startup purposes)
Scoot...should only need to choke center 2 carbs to get engine to fire... Didn'tknow ya needed chokes in Cali??? haha
this is kind of like a lolipop baffle in a drag pipr of a motorcycle? It changes the veloicty of the air flow. I too am going to run a 6x2 setup for SBC but most likely only the 2 centers will work the outters will be dummys. Anyone have pictures of linkage to connect the two center chokes?
I hooked up both chokes on my 2 deuce setup just because I've never seen it done. I did it for shits and giggles. My Deuce had the choke rod already there. It will be a lot harder on 6 deuces where the carbs are side by side and not lined up. Can it be done yeah probably but it would take a lot of engineering. I suppose you could use 2 choke cables, 1 for each side but it's really unnecessary. With 2 carbs, if you floor the gas pedal twice, it'll start right up. You may need a few seconds for it to warm up before it runs smoothly but getting it to start should not be a problem. Personally I don't think it's worth the effort. It could end up looking rather dumb. JMO
Probably don't and I'm going to start out running without them, but mostly I was thinking ahead and was also just kind of curious. Hadn't really seen it done.
All six of my carbs have a choke...that being said i've never had to use it to get the motor started...even in 30 degree weather. Definitely talk with uncle max, my carbs work FLAWLESSLY with straight linkage..doesn't bog down when crusin, and is the motor never skips a beat when you get on it... UncleMax is the man!
Scooter, what engine is the 6x2 setup going on, mild build,etc...remember if you need to you can pregress the outside four, also they can be of smaller venturies, ie..stromberg 81s or what ever holly makes. Stock strombergs can be jetted down and a smaller power valve..I agree 100% about the chokes being left in for better flow. You might have to run two choke cables because they are opposite of each other not in-line.. A mild built SBC should handle 6x2 with progressive linkage.. Would be gald to help you in any way I can... HAPPY HOLIDAYS.... Duane.
You'll need a choke in Cali little brother, unless you plan on garaging that car it's entire life. Anything left outside in the cold seems to HATE to get warm. Personal experience. Either way you will have to let it idle until warm and smooth..........sorry, no turn key and vroom vroom. =O) Progressive is nice but straight is freaking sexy. If it were my car, knowing how it'll be garaged and etc, run straight minus the choke. Unless you can find a really awesome way to run straight with choke. Never seen it, but wouldn't mind it.
I would think that only one or two would even need to be opperational, your primary carbs Im up here in the cold of Michigan, and the center of my 3x2 is the only choked carb
I agree.......but now that Tindall's pic showed up, it's kind of neat looking, but probably more work than I'd EVER want to do. Especially on a hot tempered Hemi.
yeah i dig that too, all the linkages and rods, sweet. probably only have to half choke that one, or maybe even less, wouldnt the other carbs pull raw fuel too with the choke butterfly closed?
i say leave the chokes out. none of the carbs on my 3x1 setup have chokes. i have started my bird in 17 degree weather with no more than 3 pumps of the gas pedal.
T-birds have exterior and interior fenders with a hood. That's like hot boxing an engine, a sauna if you will. Leaving off the fenders and hood, would mean that the warmth from the engine would be lost and take longer for his Hemi to warm up..........at least that's MY assumption when you start considering ambient temp and stuff. I'm a woman, I'm complicated.
Not the replies I expected at all. Interesting. I figured the reaction would be more like, "You don't need no stinkin' chokes! It's a hot rod!" Seems there are other thoughts. The replies are also interesting regarding having the butterflies intact, rather they're used or not. I was just going to run a bolt through them, but maybe I'll reconsider and put all of them back in, but only make the middle two operational... Hmmmm.... I can run them side by side off one cable using a "dual pull". Ran one on my Triumph so I could pull the throttles on two carbs with one twist grip... Interesting replies! Thanks guys! Would like to see more clever connections for Holley 94's, if you have them. THANKS!
Yep... That's my Hemi... Definitely complicated, but definitely NOT as complicated as my dear sis'...
Ah....right on. I have a 4x2 set up progressive and if needed, I just close chokes by hand on primaries... Usually starts right up without choking with just alot of pumping...lol.
Here's the cable splitter I was talking about. Pull two cables with one. http://www.steadfastcycles.com/cart/index.php?main_page=product_info&products_id=1873
An oldtimer I know has a '39 sedan with an Olds motor with six Strombergs. I noticed a golf ball laying on his intake manifold. I asked him what's up and his said that's my choke. He drops it in one of the carbs and voila!!
On my 6x2 Holley 2100's (94's). I dont run any chokes. I have a bolt going across where the choke shaft would be. I too have heard that if you take them out completely it is worse. I dont have a hood/bonnet either, so I dont get any under hood warm up. Last week I drove it and the outside temp was 19F. I had to let it warm up a little and I upped the idle a little just to make it easier at traffic lights. I have a manual trans so I can blip the throttle as needed. My biggest problem is that I dont have any kind of heater inside the car so it was kinda chilly! My opinion == You dont need no stinkin chokes in So Cal Forget em and get something else done on your car! cheers ricki
No chokes on my old set-up but had to cut fuel pressure down to 2lbs to work due to the common problem with Strongbergs "flooding out" or valve sticking. Then no high end power with 2 lbs, so blocked off front & back 2 and worked fine as a "cruiser".
