I been toying with the idea of building a towtruck since I pay alot of money to a company to come and get my stuff. I have only seen one built from a 50's truck. I would like to see if you guy's have found something or have one I can get some idea from Thanks
http://www.jalopyjournal.com/forum/showthread.php?t=164719&highlight=wrecker http://www.jalopyjournal.com/forum/showthread.php?t=328231&highlight=wrecker here is a couple
I have seen wrecker made from the early Ford trucks from the 30's all the way up . I saw them at the NSRA and shoes like that . Most I have seen use a tube beam with steel cables and pulleys with an electric winch . Pretty simple but I really don't think they would use them . If for looks you can go that way but if you really want to use it , then you will need to go with a bigger truck . Retro Jim
I have a picture of a homemade model t wreaker, it used another set of t rails for the boom or whatever. its in the background so its hard to see. anyway it is very expensive to insure a tow truck, and if it looks like a tow truck then it is a tow truck.
I didn't see that one in the back , but I have seen that way done also . Do like the rest . Just get the truck done and get the street rod tags , then stick the non working set up on the back . No one will say a thing . Retro Jim
If you are looking at ideas for a roll back; check out the cabover thread: http://www.jalopyjournal.com/forum/showthread.php?t=219018
