Using my little Lincoln MIG set up on gas, and everything is wired correctly. I have checked it 3 times. Last time I used the welder (a month ago) everything worked perfect. It has set in the corner since. I am now using it and three times now the wire has started glowing red hot inside the welder, between the spool, and the feed mechanism. Then is smells like the coating is burning off the wire, and it stops feeding. I have pulled the wire out of it 3 times, and re-fed it, and sometimes it will let me weld for 30 secs or so, and it does it again. What am I doing wrong?
the olny time any of the migs i have had did that the wire was touching something inside the welder. i didn't have all the parts for tension on the spool, and it would work loose.
