What short water pump for a 327???
Discussion in 'The Hokey Ass Message Board' started by OldCarPilot, Sep 19, 2010.
  1. OldCarPilot
    OldCarPilot
    from Bel Air MD
    I got one for a corvette but it is VERY different than another one I have. What do I need for a "normal" short water pump? The "corvette" one is longer than the other "short" water pump that I have. I need the shorter one!
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Yes, short non vette
  3. 55chevr
    55chevr
    Corvette has bigger shaft ... get a flow cooler if you can ... really works on my 55 Chevy
  4. The vette style are also a 3/4 shaft compared to the others that are 5/8.
  5. OldCarPilot
    OldCarPilot
    from Bel Air MD
    I know, now, all of the above, but what year car to get the pump from??
  6. just go for 1967 chevy belair with a 327 at the parts counter
  7. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Everyone is right here ,Theres a short one and then theres a little longer one and then there is the long one .I would look into 69 water pumps .You could make spacers and use a short water pump.
  8. SmokinBill
    SmokinBill
    I have the same Corvette water pump and all you need is a drill bit from ace hardware. drill the pulleys and fan out and remove the back of the pump ,support the shaft and use a press to position the pulley mount as needed to line the belts.[​IMG]
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Oh miss read your thead, just about any Chevy from 55 thru 67 with a SBC.
  10. Von Rigg Fink
    Von Rigg Fink
    from Garage
  11. I have used Flow Cooler water pumps on two of my cars, '70 chevy pickup and '40 ford pickup with sbc, and did not have any line-up problems with either. I will use one on my Model A also.
  12. Model A Vette
    Model A Vette
    The Corvette pump which has the pulley slightly farther foward is used on '84 and up Vettes with a serp belt so it doesn't turn in the correct direction for a V belt drive.
  13. squirrel
    Short water pumps were used on all small blocks thru the 1968 model year...some of the truck pumps had a big bypass connection on the top, and I've seen some minor differences in how far the fan hub was pressed on (you can move it a little if you need to, if you have a press).
    Like they said, many of the vettes had a larger shaft and bearings, so the pilot is bigger.
  14. I believe short pumps were used in trucks until the end of the 72 model year.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Ok heres more info,
    55-68, 5/8 shaft, 5.603" in length. (non vette)
    71-82 Vette, 3/4 shaft, 5.795" in length
  16. squirrel
    Yes, they were.
  17. Gman0046
    Gman0046
    If your building a Tri 5 it doesn't matter wether its a long or short pump if your radiator is mounted in the 6 cylinder position. My 56 with a hard hitting 350, long pump, shroud and stock radiator in the 6 cylinder position you couldn't overheat it if you tried.
  18. it may be hard to believe , but at one time all there was available for water pumps for a SBC was short
    a rebuilt Cardone # 58-129 has always served me well on mild sbc's
