What's the most popular green primer color I see alot on some of these cars,I need to know the brand ,Someone I know wants to primer and sell his car in this color.
Most likely its DPLF made by PPG its called a gray/green epoxy. Not sure what number it is 90 is black and 70 is red i think.
DPLF Epoxy Primer comes in 6 colors; DP40LF (Gray–Green), DP48LF (White), DP50LF (Gray), DP60LF (Blue), DP74LF (Red Oxide), and DP90LF (Black).
"Green" primer is zinc chromate and will stick to all metals . Provided they are clean.Great for painting chrome or stainless trim pieces. Chryco
Yep... that's the green primer that comes to mind first. It's good stuff. KP2CF ... parts A and B The color is about like a Fannie May mint meltaway.
this is a military water base epoxy I just bought some off of *-bay got 2 gal for 60 bucks shipped .... hope it helps
DuPont has 2580CR epoxy that is green. 2510s- light gray 2540s- med gray 2570s- dark gray 2590s- black Just about every paint company has colored epoxy primers- just remember that all epoxy primers fade out in the sun. You might try using flattened urethane topcoats. You can get the auto paint store to match it to the color you want. If price is an issue try an industrial flat topcoat. Most large auto paint stores carry industrial paint also.
