clutch problem need help quick?/???
Discussion in 'The Hokey Ass Message Board' started by 40hemicpe, Aug 6, 2010.
  1. 40hemicpe
    40hemicpe
    from anaheim.ca
    ok just installed my pressure plate diaphram style...bolted everything else together then slide trans in then problem number 1.throw out bearing is to long. then i go get another one then its to short"had 1/2 inch play before it touches the pressure plate i heard that it is supposed to barley touch the fingers .now i know i have to get the middle sized one. but with the short one i was able to get contact and move the fingers but when in gear tried having my friend turn the yoke when i held the clutch fork and no movement also the fingers feel really tight when i had the large bearing with the trans out. and pull the fork it wouldn't budge the pressure plate???also my setup is hydralic/slave cylinder not hooked up yet...
    motor is a sbc 350 with 4-speed saginaw 11inch clutch??
  2. The_Monster
    The_Monster
    what kind of trans are we talkin about here?
  3. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Yea.
    Motor and trans please.
    Kinda like this problem i had with this thing, but when i asked if this one thing was better than this other doohicky, nobody could tell me! :D
  4. tjet
    tjet
    1. Early Hemi Tech
    Does your fork have a thin metal steel piece riveted to the back side of it? If so, make sure you didn't get the aft bearing flange stuck between it & the fork. I've seen that before & it will cause a very hard pedal
  5. 40hemicpe
    40hemicpe
    from anaheim.ca
    fork is installed correct
    and motor is a 350 with 4-speed saginaw 11inch clutch diaphfram style...
  6. 40hemicpe
    40hemicpe
    from anaheim.ca
    tried looking came up with 2 size throw out bearing that might work
    1.580 or
    1.525 anybody have some part numbers for these sizes if the long throw out bearing was 1/4 inch shorter it would probably work???
  7. 40hemicpe
    40hemicpe
    from anaheim.ca
    just got ahold of the short one and used an adjustable pivot ball everything is back together.used an clutch a adjustable wrench on the fork end when trans was on the jack lowered and pull the fork forward and finally the clutch released turn the yoke as i did that and turn no problem.but when i bolted the trans to the crossmember i couldnt get good leverege and couldnt get it to work when my slave cylinder is hooked up it should put more pressure then me to fully release the bearing right???
  8. When I was dicking with my t-5 install, I could not get the fork to move with just hand pressure. I think you need the leverage?
  9. JohnEvans
    JohnEvans
    from Phoenix AZ
    Unless you have 5 foot cheater bar or your name is Superman ya ain't moving it by hand.
  10. 40hemicpe
    40hemicpe
    from anaheim.ca
    so when i install the slave cylinder it should have the force needed to move the clutch fork all the way???
  11. JohnEvans
    JohnEvans
    from Phoenix AZ
    Yes .Jost be sure your M/C and slave cyl. bores are the same or within 1/16 of each other. Chevy P/Us used a 1&1/8 master and a 1&1/16 slave as I recall for an example.
  12. 40hemicpe
    40hemicpe
    from anaheim.ca
    i had a mechanic friend tell me that trying to release the clutch bearingby hand in first gear is harder then doing it in a taller gear????
  13. It would just be harder to spin the output on the tranny. I think third gear is 1:1, But I don't know nothin'.
  14. 40hemicpe
    40hemicpe
    from anaheim.ca
    running a 4-speed
  15. Buck Sharp
    Buck Sharp
    from nebraska
    Changing gears wont help. You need at least a 12 inch crescent to move the fork hard enough to disengage the clutch. I had to pull mine just to get it to slide into place what a bitch that was. the slave will have the force needed to move do the job.
  16. 40hemicpe
    40hemicpe
    from anaheim.ca
    thanks for the reply...i used a 12 inch crescent when i had the trans at a angle{trans was angled down} and it worked i guess i got worried when i put the cross member back on and couldnt get a good hold/leverage.so made the bracket for the slave so will report back with how it works...:)
  17. gladeparkflyer
    gladeparkflyer
    top gear in 3 AND 4 speeds is 1 to 1. shouldnt make any difference as far as shiftin goes. hook up the damn clutch, make sure its bled good and drive! :)
  18. 40hemicpe
    40hemicpe
    from anaheim.ca
    well finished my slave cylinder bracket today and installed everything. as soon as i step on the pedal it move really nice still need to bleed the system and get an adjustable push rod for the slave cylinder:D. really happy with the hydralic setup.also it worked out with the size of the master and slave because when i barley push the pedal it moves the rod..
  19. gladeparkflyer
    gladeparkflyer
    outstanding!! i've never had a hyd. clutch that didn't drive me INSANE tryin to get it bled.
  20. 40hemicpe
    40hemicpe
    from anaheim.ca
    there's a vid on youtube how to bleed a slave cylinder its pretty cool.check it out:D
  21. 40hemicpe
    40hemicpe
    from anaheim.ca
    well now i am going insane also.. bled the system when i cracked the bleeder screw just fluid came out no air. pedal seems the same as when i just filled it up with fluid without bleeding it....other problem is.when my pedal is to the floor i am watching the clutch fork move and it looks like it is working ..but it wont release the pressure plate when i step on the pedal all the way and put the trans in gear and try to turn the drive shaft it does nothing just turns in neutral..is there still trapped air???
    using a 3/4 wilwood master with thru firewall mount
    with jeep 7/8 bore slave cylinder.these parts are all new..
    throw out bearing is a short with 1/4 play if moving the fork back and forth with slave cylinder not hooked up..am i missing something here have till the end of the month to get car ready to drive moving so i need help quick..
  22. 40hemicpe
    40hemicpe
    from anaheim.ca
  23. JohnEvans
    JohnEvans
    from Phoenix AZ
    MC is too small . The MC bore should be the same or slightly larger bore than the slave. You check out the specs for bore sizes on factory systems thats what you will find. Example Chevy PU MC bore 1&1/8 slave bore 1&1/16th.
  24. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    for a 7/8s slave you need a 1 inch master
    Think if it like your master is a beer can, and your slave is a 5 gallon. Not quite enough to fill it. When you step on the clutch, your master isnt moving enough fluid in your slave cylinder to make it actuate all the way
  25. 40hemicpe
    40hemicpe
    from anaheim.ca
    thanks will check into that.is this for sure the problem???
  26. meengrinch
    meengrinch
    from ipswich ma
    well i think i have had this same problem.........my fix was that i had the wrong pressure plate for the short throw out......i had to use a 3 fingered pressure plate instead of the multi fingered plate.......just what you need is another experts opinion...lol......good luck
  27. 40hemicpe
    40hemicpe
    from anaheim.ca
    i tried the long throw out bearing and the trans wouldnt even bolt up then i got the short one everything went back together fine..also was told that its ok to have some play between the throw out bearing and pp and thats what an adjustable pushrod would eliminate?
  28. 40hemicpe
    40hemicpe
    from anaheim.ca
    well called wilwood they suggested the 3/4 master and also said they also suggest 3/4 master with 7/8 slave with there kits?? guess there is still air in the system then..
  29. 40hemicpe
    40hemicpe
    from anaheim.ca
    also checked what my slave cylinder worked with originally and it worked with a 13/16 bore clutch master cyl?
  30. JohnEvans
    JohnEvans
    from Phoenix AZ
    Believe it or not there is a noticeable difference between 3/4 and 13/16 in the amount of fluid moved.
