I bought it thinking it was a 32 and someone told me its a 33 or 34 ,Then I checked a guys build here on the hamb same shell says his is a 32
I have the same one ..was told by some it was 32...others 33..I just think it looks cool..My peak above the emblem looks not as pronounced as yours though..humm..
Defnitely not a '34... Either '32 or '33 but I can't tell from those pics. A side shot to see the depth would produce the answer. Are there raised slots around the edge of the grille for a trim piece?
32's pictured when the car was in primer are narrower than the 33's and 34's as shown with the car in paint Not by much but it is noticeable and I was told that the 32's didn't have a trim ring... however mine had the holes for that ring! Could it be because it was from a Pick up?
So what are the exact year-by-year differences in these shells then? Is '34 the slightly sloped version? How do you tell a '32 from '33?
its a 33 grille 32 and 33 are close, but the 33 is thicker, and 33 has two crank holes in the bottom (on the inside), 32 only has one 34 truck grille has a stainless steel trim around the grill bars so there are holes for clips and they have a bolt on chrome peice were the badge and rad cap go. i can tell just at a quick glance Wingnuts, i would assum someone drilled the holes for the clips, ive had about 5 32 commercial shells and not one have or had the trim jeff
Hey Jeff.. is my old shell a 32 or a 33? It's definitely not as thick as a 34 but it has the slots for the trim ring clips??? Is there a difference between the Pick ups and the commercials?
your old shell was a 32 the 33 and 34 are the same thickness, 34 just has the chrome bezel and the trim ive always considered pick ups as commercial, they also had painted headlight buckets too
New pics .I hope this helps Id year .Ford barn was no help either I loaded these and you guys already figured it out .Its a 33 .Ill take your word ........................And Thanks
I think that one is off a 33 nissan!!! You dont want to use that one do you!!!!! I mean a foreign jap crap piece on your nice ford vehicle. I will take if of your hands and dispose of it properly. Knuck from indiana.
Well thank god thats over and thanks for the lesson in truck grilles .Ill be able to tell the difference now. I just have to stop buying stuff on impulse .I figure I wouldnt get hurt ,
