Cheap n easy lake header baffles
Discussion in 'The Hokey Ass Message Board' started by skwurl, Jan 14, 2010.
  1. freebird101
    freebird101
  2. Rotobo
    Rotobo
    Squirrel
    Crap, I just gave away two used bombs. AND I'm going to run lakesters. WTG.
    It'd be hard to stuff a flowmaster in lakesters but I bet someone here has cut one up to see. HEY, I got one of those, is it a go? Reckon the dude will let me have one back?
    This site rocks and this post is tops.
    Remember when Hot Rod mags did articles like this?
    If you can't hear it before you see it, it aint a Hot Rod.
  3. Hotrod1932
    Hotrod1932
    from Oregon
  4. skwurl
    skwurl
    Thanks for all the positive feedback guys. I hope it helps someone down the road.
  5. holeshot
    holeshot
    from Waxahachie
    SKWURL...very good young man. because i can guarantee the baffels my son baught for his lakesters had very little effect. not only is your idea quiter, but i believe they allow good exaust flow...POP.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Neat, has anyone bothered to cap the baffle? Mite choke things up, just looking for peoples results.
  7. skwurl
    skwurl
    I thought about that. You would need to drill a hole in it . Maybe cover half of the hole.
  8. bought myself a thrush muffler last night and finally came up with something to get the po-po off my ass... great idea and works very well. i ended up welding a washer on the inside to close the opening a little and think it sounds pretty damn good now. thanks again for the idea...
  9. Creature13
    Creature13
    This is what I did, but I flipped the ends. I also used larger baffle insterts and double wrapped glass so it was jammed up between ths baffle and the header wall. I secured the glass using steel bands evey 1". They sound nice and deep. And, the glass is holding up.
    A summit glaspack cut in half
    Invert the end and weld
    double wrap the glass and steel band
    Insert
    Bolts are facing in when mounted... not visable unless you are reall looking for them
    Mounted i flush with the opening with a good seal
    Mounted on my 1930 Durant
  10. movingviolation
    movingviolation
    Damn, that is slicker than snake in a bucket of snot...
    I'll be trying this out forsure.........
  11. Creature13
    Creature13
    Using the larger diameter baffle allows you to bottom out in the cone. This, the banding, and the flared end keeps the glass from blowing out.
  12. Hot-Rod-Howard
    Hot-Rod-Howard
    Just wanted to send my thanks to skwurl for this thread. Just put baffles in my 36 plymouth and my old man did the same to his 26 ford over the weekend. Worked great. Cheap and easy. Took both cars to a small car show on Saturday and got many compliments on the them. Thanks again.
  13. Gator_13
    Gator_13
    I built my lake headers with 3" end and have an adapter plate for my turnout. I welded on the inside of the turnout a 2" tube 7" long with a solid cap on the end and about 15 holes in the sides. When I bolt the turnout on the end the 7" tube gos up inside the pipe. If I want the baffles removed, I just remove the turnouts.
    Just another Idea...
    Gator
  14. zombo27
    zombo27
    from E-town Ky.
    Just did mine. Quite an improvement on the decibel level. And only 20 bucks!
  15. HuffDaddy
    HuffDaddy
    Good stuff, I'll be using these ideas.
  16. humpie
    humpie
    I put these baffles in my A-model about a month ago,now we can talk while going down the road.I also added a pair of 90 degree turnouts at 45 degree to the road which also improved noise in the car,thanks for the idea.
  17. skidsteer
    skidsteer
    That's a good one, I may try it with my tailpipes, at least for state inspection time!
  18. STRANGERODZ
    STRANGERODZ
    from WASHINGTON
    Hay, just got my bomb and am going to do the same. I love saving money..........
  19. Gearhd69
    Gearhd69
    I found this thread first thing in the morning and with in an hour I had a set made for a set of regular headers.
    Awesome thread!
  20. 41 C28
    41 C28
    Great tech, thanks for posting.
  21. My Son just sent me this link, Glad he did. now I can't wait for a swap meet to pick up some old cherry bombs
  22. johnny_rocket88
    johnny_rocket88
    we are gonna do this to our lake headers from gear drive we baught the glasspacks today, was this car in ol skool rodz?
  23. Harvey29
    Harvey29
    from kansas
    Gonna do this for sure:D
  24. smitty29
    smitty29
    from Illinois
    Just stumbled across this looking for a solution. Sure beats 150 for a weld in kit. All I can say is Thank you and you are a genius! Super cheap, and fast.
  25. Gearhd69
    Gearhd69
    I liked this idea so much I have made 3 sets for my father,son and myself. The new set I made today. 20200209_140745.jpeg 20200209_141034.jpeg 20200209_145952.jpeg
    Sent from my SM-N960U using The H.A.M.B. mobile app
