i want to do a real nice column shifter for my 39 Ford truck build...i have ordered a Limeworks 1.75" polished column and would like some cool brass collars to hold the shift rod....who should i call....thanks....bryan
Hi we make a new column shifter column with neutral safety switch & PRN lock out. Available 1 1/2 now 1 3/4 very soon . Can be retrofitted to any column . Below are some quick snaps of the prototype shifter in Carol's Fordoor.
your on your own there, you could use the factory parts if it has an external tube, that would then clamp to our column, just a thought. I don't plan on making a shifter for manual trans though.
