Quick ? R the 1980 Granada Spindles the same as the Mustang II Spindles? I was told by 2 other sources, they're the same size and will fit the Jamco tubular arms I'm planning on purchasing in the next few weeks. I'm very Thanks GC
I think it will fit the ball joints, but the Granada is rear steer, the MII is front steer, so you wont be able to use the steering rack. I think it's longer ball joint to ball joint, but not sure on that. This would change the suspension geometry as well.
I'm only planning on running the spindle disc conversion on my 49'. How bad will it change the suspension geometry?
