I've been searching for a new sending unit for my '63 Valiant and found two options. Option 1:http://http://www.classiccarautoparts.com/gastank_sending_units.html It says there are two lines. What is the second line for? (Can you tell I'm a novice?) Option 2 is another sending unit that has 1 line.... Any insight is greatly appreciated!
Have you tried WildCat Auto Wrecking out in Sandy?? 503.668.7786 ...and I agree with 440roadrunner on the return line... .
Hey I have the same question...for a 1964. I had not even done a Google search yet, but I new there might not be a new one made...obsure model of wagon. Hoep there is... WIll look, but that link you gave in the beginning...no such company. And I removed the, "...ing units", of course. www.classiccarautopart.com Nope. Where'd you find one on a site that doen't even come up?
hey guys, i got my sending unit from laysons restorations. i went with the 3/8" sending unit in case i ever go with a big block. i also have a new gas tank and all new fuel line from the tank to the carb. and my gauge works intermittently. there is a fix for that though. what happens is the voltage limiter for the gauges (which is located in the fuel gauge on these early a-bodies) go out. there is a company that sells a solid state voltage limiter that will fix the problem. they show you how to get rid of your old one and wire up theirs. here is their link: http://rt-eng.com/mediawiki/index.php/RTE_ABlimiter or you can do this: http://www.slantsix.org/articles/instrument-reg/instrument_reg.htm hope this helps.
oh, by the way. my sending unit had two lines. original one had one line. the other is for a vent. i just caped mine off. here is a link to my build so far. http://www.forabodiesonly.com/mopar/showthread.php?t=40597
That's not a real link (??): ====== Option 1:http://http://www.classiccarautoparts.com/gastank_sending_units.html It says there are two lines. What is the second line for? (Can you tell I'm a novice?) ======
http://www.vansauto.com/sending2.html Vans Auto has a 3/8" one for '63-'76 A-bodies for $50. That's where I got mine.
