What are you running for power steering in your 57-60 ford pickup?? I have seen som rack and pinion setups on line. Does anyone have any experiance with those?? I have been playing around with some set ups, whats yours??
I have the set up offered by Sacramento Ford. It is a toyota box and you hook it up to your own power steering pump It uses the stock draglink. The guy I got it from loved it. I never put it in my truck, maybe someday. Or if someone else can use it. good luck
I put the Toyota 4x4 power steering kit from CPP in my 58 pu. I have 15x10 wheels with 295/50-15 tires all the way around and it steers just fine. It's not a real fast box but it's better than arm strong.
