How to clean out a rear end?
Discussion in 'The Hokey Ass Message Board' started by tschmitt, Oct 25, 2009.
  1. tschmitt
    tschmitt
    from IL
    I sandblasted my ford 9 inch after disassembling it and now it has some sand inside the housing and axle shaft area. I have sprayed the inside down with brake cleaner and then sprayed it down with water but there is still grease and grime in there. I will be having a local speed shop install the posi and setting everything up. Is it possible to have a rear end housing hot tanked? Are there any other recommendations for cleaning this thing up?
  2. bobwop
    bobwop
    from Arley, AL
    find a parts cleaner and flush it for a LONG time.
  3. Al Napier
    Al Napier
    from Central CT
    Car Wash maybe? Bring a bucket, sponge and bottle of Dawn dish washing liquid too.
    Al in CT
  4. oilslinger53
    oilslinger53
    from covina CA
    I believe it's called a colonic... doesn't sound too appealing if ya ask me!
  5. pasadenahotrod
    pasadenahotrod
    from Texas
    Carry it in your pickup bed to the local car wash. Spend a few bucks with nice hot soapy water blasting it from center to ends and from ends to center then rinse thoroughly for another buck or two. Wait until bed drains clean, then go home and dry it out. Should be clean as a whistle.
  6. skunx1964
    skunx1964
    pppfffftttt!!!! :D
  7. colorado kid
    colorado kid
    from Colorado
    i had my rearend hot tanked then blasted
  8. Beta
    Beta
    from Central WI
    That sounds downright painful!
  9. Deuce Roadster
    Deuce Roadster
    I take mine to a local " big machinery repair " place that works on big diesels.
    Their VAT is large enough to dip a 1966 VW bug :) and nasty enough that they do not care what you bring in.
    In on Friday and dipped all weekend ...They come out CLEAN on Monday :D
  10. RodStRace
    RodStRace
    With sand blasting and bead blasting, I would not be comfortable with a pressure wash or rinse. Get in there with a brush too. Go with whatever soap/chemical it takes to get the gunk out, since this is a bare steel housing.
  11. brucer
    brucer
    from western ky
    Try some easy-off oven cleaner and pressure washer..
  12. poboyross
    poboyross
    from West TN
  13. Casey
    Casey
    I worked with a old chassis builder he put a gallon of kerosene in them and let them burn at night they come out really nice and clean
  14. scottybaccus
    scottybaccus
    I uses an engine brush for a 3" bore or a toilet brush and a couple of cans of brake parts cleaner.
  15. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I had mine media blasted before i tore it down..it keeps the shit from getting inside.
    the very small areas that couldnt get blasted because of it being assembled were easy to clean up..
    after having my gear ratio changed and axles cleaned. I painted the axle shafts, and used kerosene and rags and cleaned out the inside..she sparkled like new
    i didnt want sand inside my housing there are somany places for it to hide and never get it all out..so i elected to have it blasted while it was all together, minus the backing plates.
  16. pull the axle seals out so you can get inside the axle tubes to clean them out with a brush...you will need new seals anyway. i go to the car wash too with some brushes , a couple cans of engine cleaner and a bunch of quarters
  17. oj
    oj
    I have them hot-tanked. Some are too long for the tank and they'll keep it an extra day to flip it around but when you get it back all that imbedded oil/grease/goop is gone and if you sandblast/grind/whatever the grit won't stick to anything. Your hands'll stay nice and clean handling it too.
  18. Mr Haney
    Mr Haney
    beer and brotworst....no seriously
    like HRP said hot tank it is the best way . take it to your local engine rebuilder drop it off, pick it up. Same price as 10 cans oven cleaner, no mess in your garage, absorbtion killing your liver, early death.
  19. 8-Track
    8-Track
    check around with some engine rebuilders and se if they have an oven big enough to fit your housing and have it baked. all the grease turns to ash and falls out, its the new way to clean up parts
  20. 29nash
    29nash
    from colorado
    HOt soapy water. Scrub, scrub, scrub.
  21. TagMan
    TagMan
    .....and then scrub some more. Make it as clean as you can and remember that one little speck of sand getting into a bearing can ruin it. I personally would never sandblast the interior of anything that will later have bearings running in it.
  22. tschmitt
    tschmitt
    from IL
    Thanks for all the ideas guys. I only sandblasted the outside of the housing but some sand got inside the housing that had oil in it and all the sand stuck. I'll try out some of the ideas and hope for the best.
  23. Bruce Lancaster
    Bruce Lancaster
    I think you gotta hottank it or equivalent like baking. That crud in unreachable places will be VERY hard to clean out reliably by hand, and with sand in there you don't dare miss a single speck. Once it is degreased, detergent and hot water will help you be sure that sand and other non-soluble/bakeable stuff is out for sure.
  24. Hot tank !
  25. Johnny1290
    Johnny1290
    FWIW I had a 3rd member shipped to me in a sawdust filled bucket, wouldn't even turn. Took it to the carwash and pressure washed the hell out of it and its worked fine since.
    Personally, I think hottanking or what have you is great, but I'd never trust it to get all the sand out of there, I'd still take it to the car wash. good luck
  26. SanDiegoJoe
    SanDiegoJoe
    I second the Oven cleaner method
    Apply a thick coat..
    wait.
    Scrape the guck with a putty knife.
    wait.
    wait.
    wait.
    wait.
    Should be pretty clean by now.
    - Joe
  27. Bruce Lancaster
    Bruce Lancaster
    Anytime you introduce something that isn't soluble like glass beads or sand, you MUST clean with detergent, but you need to get the petro type stuff out of there before you can do that. A rearend is not easy to clean by hand due to the heaviness of the crud, and there is no way to see all the nooks. Hottank is only way to be sure, and then hot water and detergent to remove any leftover sand, steel, and other leavings. A few leftover grains could trash your gears.
  28. The Gambler
    The Gambler
    thats gotta hurt!
  29. Muttley
    Muttley
    I heard this stuff works great.
