ok so in my travels i have found two erly hemis first the 325 its a short block that was never used he said he found it in the 80's in a old factory its complet less heads and intake its basicly brand new the casting date is 1958, the 241 red ram is complet (intake to pan) but it needs rebuilding as it is used casting date 1954 and also included is a new tri power intake setup with carbs now for the price the guy wants 1500.00 canadian (about 1300.00 US) is it worth it? i think it is but i just want some input? also what tranys will bolt up to them?
A 241 3X2 new from Hot Heads is 350$, carbs extra. Say a couple hundred for 97(?) cores. Leaves 700 for a 241 seems maybe a little high, maybe not.. A rebuilt short block, with proof of rebuild, might be worth it. put hemi tech index in search. There's a 315 build & 241 build @ www.webrodder.com If that's for both, grab em!
