I need help with a master cylinder rebuild
Discussion in 'The Hokey Ass Message Board' started by modelaratrod, Jun 24, 2009.
  1. I'm trying to rebuild the master cylinder on my 48 Fleetline, any one know how this should go?
    Thanks in advance..
  2. Retro Jim
    Retro Jim
    If you have a good GM manual you should find that information there .
  3. mojo273
    mojo273
    If he had a good GM manual he wouldn't have asked the question...:(
    Thanks to 440roadrunner meaybe he'll have it together tonight. geez
  4. Mr48chev
    Ah hell, I'll leave off that comment.
    Anyhow "after" you have honed the cylinder and cleaned it well, With brake cleaner or soap an water like Dawn dish liquid not any solvent based cleaner.
    If there is a thick rubber washer it goes in first,
    The the spring with the check valve in first
    Then the cup with lips in.
    Then the piston with the end with the holes next to the cup and it's cup at the back
    then the rod with the snapring holding th washer on the rod in place.
    The boot slips over the rod and goes around the end of the cylinder.
    Then fill it with fluid an bench bleed it.
    And this week if you ask what "bench bleeding" is your penance will be scrubbing ever Fellow Colorado Hamber's garage floor.
    As Usual, 440Roadrunner types faster than I do.
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
  5. Thanks 440 and 48 does this look right?
  6. I honestly don't remember....:confused:
    Is this how 48chey explained it.
  7. Thanks 440 and 48 for all the help.
    Here's a preview of the "GO" now I need to finish the work on the "WHOA"
  8. budd
    budd
    thats a rebuild kit for a duel master correct?
  9. No, It's a single outlet.
  10. Nice post and some good clear advice.
    I'm about to open mine up(54) tomorrow for similar rebuild - or at least to see if the inside is ok. $140 - $190 for NOS, or $29 for the kit and @ 15 for a ball honing tool, hmmm, think I'll do it myself.
    I ordered a manual for my truck last week before it arrived, and expect it in a few days. Soon I'll know it all. :rolleyes:
    How does the master cylinder come apart - any tricks to it? I have not rebuilt one yet, and don't want to damage it or have parts fly away upon disassembly.
    What's the general guideline for bore inspection - how do you decide whether the bore is suitable or not for rebuild, or do you hone it first then see? It's been sitting for 7 years, with fluid in it.
    Last, but not least, what prep is involved / ok? can I clean out the inside with anything like soap / water or should I use brake fluid only in it, or?
    When you hone these do you run it dry or with some WD or H20?
    Can't wait to drive my truck, but has to be safe!
    Thanks!
    hdh
