Guys, I think it may be time to go through the old powerplant on my chevy. Does anyone know what the going rate is for a rebuild on a 235 I6? I could do it on my own but it would probably take 4 times as long (I have never done one before), and might cost more from screwups. Didn't know if there was someone in the Houston area who knew of a ballpark to how much this would cost? It would pretty much be a straight rebuild with probably some upgrades to a 2X1 barrel intake, and dual exhaust manifold. Thanks in advance.
I have no idea about the cost, but call around. There are plenty of engine shops in Houston. I've used Joey's Engines numerous times in the past, they are pretty economical http://www.joeysengines.com/. There's also Jeff at Custom Automotive Machine over on Pinemont (no website, try Google). He's probably more expensive, but you can't beat the quality. Thanks for not putting in a small block!
Thanks very much! I will look into them. I really like my little 235 I6. There is just something so real about still have the stovebolt in there!!
A bit of advice----if it's a standard shift car with the original '53 babbit pounder, find a 235 with full pressure oiling and insert rod bearings, and have THAT one rebuilt for your car.
A 53 stick car with a low pressure/splash oiling system has insert rods.These engines are fine for regular driving even with a little perfromance stuff.But like the guy says,a full oil pressure engine has the potential to be better. Prices I hear from my friends with Chevy trucks is around 2-3 grand for a total rebuild,new everthing,pistons, crank ground,new cam and lifters and so on.
Not unless someone replaced the stock rods with a set of the rods that Federal Mogul converted for insert bearings years ago. I've disassembled three '53 standard shift 235s, and they all had rods with poured bearings. The '53 Powerglide engines had insert rods.
Cheaper to buy a motor. I have the 230 in my 63 and I just bought another 230 out of a 67 Camaro freshly rebuilt with a powerglide for $425. Year correct or not, it runs perfect and was in after a 12 pack with help from friends.
Yeah, I noticed that, haha. I was talking to people about buying a 235 for it and it turned out, like you're saying, its a no go. Thats funny though, are the 235s much more expensive?
Yes, they were the first of the "good" engines with aluminum pistons, insert rod bearings, and full pressure lubrication. If you're going to install a hotter cam, you may end up sending yours out to be reground; the majority of aftermarket cams are ground on the large journal '54-'62 shafts.
Thanks guys very much for the advice. I sent out a few emails to engine guys asking for quotes. The gearhead in me wants to do it all myself, I am just afraid it might take FOREVER and cost me more than letting a professional do it...
Your Chevy is really cool! How about finding a later insert rod engine(like Heathen said) and take your time to rebuild it yourself while you continue to drive with your current engine? You can do it with a little research and advice! Internal engine cleanliness at assembly time = long happy service usually. Good luck.
Yes, the 216/235/261 is more expensive to rebuild than a 194/215/230/250/292, partially due to the fact that the main bearings are 4 different sizes, and the whole lower end is more labor intensive. See the Webrodder article.
well why not get rid of that babbit pounder and get my 1956 235 one barrel,carb to pan and a 3 speed tranny to boot all for $350 and close to ok city ,ok. had motor since 1968 or 69, rebuilt maybe 8000 miles since rebuild,motor is preserved waiting to come alive again,.......aircraftmechanic
I just bought a 1950 Chevy, don't know what engine it has. All I know is that it don't turn over.Might be interested in that engone of yours. What did it come out of?
He wrote that it is a Powerglide car, so he has a full-pressure motor. Your 50 Chevy, if 3-speed is a 216. If Powerglide it is 235. If original. Check out the 216 social group - lots of cool stuff can be done with those babbit motors. Good luck.
