I have a late 235. I'm wanting to use it and an auto gm overdrive trans in my 52 chevy sedan. I've searched the hamb and see that you have to have an adapter to use an auto trans for the early 235. I was wondering if anyone could help me out with some info on what to use for the late 235. Is it the same as the early 235? I've only dealed with a chevy 6cyl in my dads combine. http://www.jalopyjournal.com/forum/showthread.php?t=56674&highlight=late+235
I'm running a '54 235 with a 700R4 using an adapter I bought from http://www.stoveboltengineco.com/acartpro/product.asp?productid=139 Best thing I ever did. Good Luck
When the sixes were changed in 63 they got the modern bellhousing bolt pattern,62 on back needs the adapter.
