inerta relay
Discussion in 'The Hokey Ass Message Board' started by dirt t, Apr 4, 2009.
  1. Ford had a relay that they used with there electrict fuel pumps. If you were in a crash or got upside down it shut of the pump. I lost the part number and am installing a ele fuel pump anybody know the part number or where to obtail one?
  2. Rob one from an old Escort in a scrapyard. They are easy to get to with a low price at most pick n pay places.
  3. Could you give me an Idea of year?
    thanks
  4. SlowandLow63
    SlowandLow63
    from Central NJ
    I think they had me in most everything from like the late 90s and up. I know all there pickups have me right under the glove box area.
  5. Von Rigg Fink
    Von Rigg Fink
    from Garage
    i know there is one in the trunk of the lincolns of that era..dont ask me why i know this:mad:
  6. mazdab2600
    mazdab2600
    any ford 8?-92 efi models.
    normal location passanger kick panel.
    try for later 87-88. the early one's are sensitive to bumping and set off easily.
    ford # e1ae-9341-a2b from 87 mustang 5.0L.
    2 styles 1st is the one listed 2nd is the newer model.
  7. 81ttopcoupe
    81ttopcoupe
    from Cedar Park
    88-93 Mustang in the trunk, to the drivers side of the latch.
  8. Merc Tracer '98. My mom's gettin around the neighborhood car has one. Driver's kick panel.
    just go to O'Reilly or NAPA and tell 'em you need one. They will be pretty much the same for about any Ford.
    Some of the Pintos (you remember those don't ya) used an oil pressure sendor to shut the fuel off if you lost oil pressure. So if you just want to make one flip proof that would work. Trust me if you turtle it, it'll loose oil pressure.
  9. plym49
    plym49
    from Earth
    80s to mid-90s vintage Jaguars had nice inertia switches that are recangular and black and have a little reset buttin peeking out the bottom. They are mounted by the passenger (right side) doorframe - very easy to get to. The button can be used as a poor man's engine kill switch when parking in a bad neighborhood, as the car won't start with the switch engaged.
  10. RichFox
    RichFox
    Tarus in the trunk on left side behind a sign that says they are there 98ish. Get the plug a new one from Ford is about $35. Which is more than the switch.
