This may be a stupid question..but I'm going to ask it anyway. Can a part that has been recently powder coated have paint applied on top of the powder coat? We had the wheels, brake drums, and backing plates for my father's 31 roadster powder coated recently. The brake drums and backing plates match the off white color of the car great. The color we chose for the wheels, which were originaly painted a kind of faded redish-orange color, does not match up well with the rest of the parts and trim on the car. Mainly the engine which we just rebuilt and painted and is in the car. The powder coat color was a stock color that we took a chance on closely matching - but it didn't. Since the wheels have center caps and trim rings, the only part of them that is visible is a small part between the caps and the rings and the inner lip of the wheels. I was planning on painting the wheels to match the rest of the car if it is possible. Thanks for any suggestions.
The biggest thing is to make sure you scuff the powder coat really well. You can remove the powder coat from the rims real ease if you want to go that rout.
I've sanded and painted the powdercoated parts on my jeep with no problems whatsoever. They had started chalking really bad. Just sanded em and rattle caned em. Look like new.
Scuff paint no problem just make sure it's been longer than 24 hrs to allow the powder to finish curing try to use a similar chemistry product, polyester base paint
I always blow a mist coat of epoxy primer/sealer after scuffing just in case. I have had powder coated rims and suspension parts do funny things on ridges and anywhere it was broken through. Probably overkill depending on what you are putting over it. Just my 3cents. Jon
I've painted over powdercoat several times very successfully . I just had my roadster frame coated with their epoxy primer powder , sanded it with 320, sprayed sealer ,basecoat ,clear ,,colorsand and rubout. looks great with no shrinkage or die-back . do'nt worry go for it !!
