Ray is a good guy and he did mention I might have to massage the hoops some. I didn't plan on this much but it's all good. Can you tell I just got back in from the shop? Yep, you're a bad influence HemiRambler. THANKS!!! ;-D Got the shoulder hoop on tonight. I tried about nine different things till it felt right. I also took another of the back hoops that was to wide, sliced a chunk out of the middle and welded it back together. It'll go in tomorrow. Man this is adictive.
I have been sittin Skip. See my broken 471 seat? I've been making engine noises too! ;-) Barring unforseen stuff I plan on dragging the digger up to the St. Paul World of Wheels next year so I'll almost be in your neck of the woods Gerg.
And heres another hoop. I've called this thing a Dragmaster but I should really say it's Dragmaster like. I have the hoops on an angle that is parallel to the top frame rail. The Dragmaster hoops were pretty much just horizontal. The hoops are also further apart than a dragmaster. It's definitely starting to get it's own feel.
I'm not sure, I'll measure it tomorrow for you. I got the top hoop so it fit me at the shoulders and put me at the right spot. I placed the second hoop 7" down, parallel to the top hoop, so the angle at the back was about 30 degrees off of vertical.
Lookin good Kerry. Those Dragmaster cars are real comfortable to sit in. Although they dont look like it.
I like do like that it very good. But it is missing the cover did you sell it get home?From the car show
BTW Brian, I need to thank you. I've referred to the pics of your earlier Dragmaster a bunch. Very helpful!
And yet another hoop. I got the bottom of the three back hoops in this afternoon. I'm giving some thought to departing from the Dragmaster style and skipping the back spine. Have to think it over.
Ray @ H&L Metals bent it. (562)426-7388 It was an $80 fee for each bend setup and he would make ten (I think) bends for that price. If he had to change the setup or use another die it was another $80. I ended up paying $160 for the bends and about $80 for the shipping. This was on top of the steel I ordered and had dropped at his place. I forget the name of that place but Ray can hook ya up. Real nice guy to work with.
