Jeep T5 trans in the torquetube
Discussion in 'The Hokey Ass Message Board' started by Stovebolt, Apr 8, 2008.
  1. dirt
    dirt
    yep.
  2. Ok I understand thanks for the clarification
  3. gerrald meacham
    gerrald meacham
    when are the kits going to be available to the HAMB world?
  4. 4-port Riley
    4-port Riley
    Rumor has it that Steve Serr of the Miller OHV conversion fame is working on an adapter to use the T-5 with the A torque tube. He's a bit slow but it is in process.
    John Heckman likes this.
  5. Flat Ernie
    Flat Ernie
    Tech Editor
    I'm pretty sure Steve's adapter is made by our own Crazydaddyo...and we're talking about the adapter in this thread. :D
  6. Crazydaddyo
    Crazydaddyo
    Yes, I'm making the kit for Steve. The one I'm making for him is for the S-10 4x4 trans. I have finaly aproved the casting patern and the first small batch of castings whent to the heat treater on Thursday. The prototype I did for Steve will be at his booth next week end at the Turlock Swap meet. If you see him, tell him you saw it on the HAMB. This adapter will work with the V-8 torque tube also, but the mounting holes are a little different.
    Kits should be availible by the end of next month.
  7. Flat Ernie
    Flat Ernie
    Tech Editor
    Now get to work on the Jeep adapter! ;)
  8. sanfordsotherson
    sanfordsotherson
    from So. Cal.
    I went and picked up an S-10, 4-WD, T-5 this morning...I'm ready for a kit now!
  9. Crazydaddyo
    Crazydaddyo
    Sanford's,
    Is your application for Model A torque tube or V-8? I ask because 28 -29 A mounting and 30-13 are different. And V-8 is different form Model A. Model A has 6 bolts and V-8 has 4. I should start machining castings next week and kits will be ready by the end of Feb.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
    Thanks for your patience!!!!!
    If you have immediate needs for this, please P.M. me and I will start a list
  10. sanfordsotherson
    sanfordsotherson
    from So. Cal.
    Crazydaddyo:
    "Is your application for Model A torque tube or V-8?"
    -It's a V-8...out of a '40 coupe, I think.
    "If you have immediate needs for this, please P.M. me and I will start a list."
    -No immediate need for me...I've got plenty more to do.
  11. Not sure how I missed this until now, but CDO should be awarded the tech week prize, excellent work! I hope you can make and sell many of these. For the buyers benfit using a better trans and your benfit as a payback for your design and machining efforts.
  12. Crazydaddyo
    Crazydaddyo
    Thanks for the kind words, ....do you want a job in our sales department?
  13. No but I would be happy to help you with any metallurgy questions. Feel free to PM me with any questions. Ernie can vouch for me, I am the HAMB Metallurgist, just do not post as much lately.
  14. fulltimeforester
    fulltimeforester
    from california
    How do I get my name on your list? I talked to you at Long Beach swap meet And talked to your friend at Turlock. Also I bet you have a marketable item with your E-brake setup
  15. fulltimeforester
    fulltimeforester
    from california
    re.
    T5 to torque tube
    How do I get my name on your list for your adapter? I talked to you at L.B. swap meet. Also talked to Steve at Turlock. I also think you have a saleable item with your E- brake setup. What do you think? fulltimeforester
  16. Flat Ernie
    Flat Ernie
    Tech Editor
    You think I'll vouch for you?!? :D
  17. brokenspoke
    brokenspoke
    E brake set up??????
  18. hellrod666
    hellrod666
    from seattle wa
    how do you take the forward load from the rearend that the engine radius rods (ford part 6044) did in the stock torque tube ford trans and rear setup?
  19. I SMELL SMOKE
    I SMELL SMOKE
    does it matter if the trans is out of a 4cyl or 6 cyl? are they the same? thanks
  20. Crazydaddyo
    Crazydaddyo
    I think 4 cyl. and 6 cly. are the same. The only differance would be the input shaft spline. But I think all of the S-10 4x4 trans were 14 tooth spline. Jeep 4x4 t-5 was avalible with a 10 tooth and a 14 tooth input shaft.
  21. What's the latest on this project? Anybody know?
  22. Crazydaddyo
    Crazydaddyo
    I've got the first couple of castings now. I'm working on the machining program and hope to start cutting chips this week. Here are some pictures of the casting. Sorry it is taking so long.
  23. bloodyjack
    bloodyjack
    hey Crazydaddyo
    Now you have me excited I just purchased the cut down-yourself driveshaft from Speedway and this is the last piece of the puzzle!
  24. brokenspoke
    brokenspoke
    Pic of the transmission mount??
  25. nexxussian
    nexxussian
    Crazydaddyo, that looks good so far.:D
  26. bloodyjack
    bloodyjack
    Its that big yellow ratchet strap you can see in the picture.
    I did make one but its on my scrap pile because like a total idiot I built it without any rubber mounting. I was not thinking that day! When I re-do it I will post a picture.
  27. Flat Ernie
    Flat Ernie
    Tech Editor
    Crazydaddyo - when you get ready to do the Jeep ones, let me know - I have an input for you if it can be incorporated into your design that would probably appeal to many people...
  28. brokenspoke
    brokenspoke
    I cant wait much longer...I've wanted this for 9 months....Thanks CDO
  29. general gow
    general gow
    MODERATOR
  30. brokenspoke
    brokenspoke
    Any updates CDO?
