Just ordered a new set of Cokers for my T modified, 450/16 fronts and 700/15 rears, (firestone blackwalls) these are bias ,4 plys. Also just got an earful from a pal saying what a mistake I just made, not getting radials. Have to admit I ordered these cause they looked perfect for the car, the radial offerings just did't seem to have the feel I am after. So what is the consensus here, will they drive O.K.or what? By the way, saved about 10% with the HAMB discount. Thanks.
You really screwed up on this one. You should be building your car exactly how someone else tells you. JH
Check out the Rolling Bones website, check the pics and see what they have to say about them.I would'nt run them if I planned to put alot of miles on.
I've run both bias and radials on my cars . A lot depends on the weight of the car and what kind of driving you do . I've found that they both work very well , I've driven long trips on both . The bias won't work as well when turning , seems like you just keep turning and turning and they roll under a little at slower speeds on my '40 coupe . Radials ride well but so do bias with correct pressures . My .02 worth............Z.D.
You did good. Your friend doesn't know what he's talking about. Bias ply tires on a small car not only drive good, but LOOK good too. Pat yourself on the back for narrowly escaping a big mistake.
I did the same thing for the 26 T roadster I am building and it looks just great. My thought is that I want it to look as much like a hot rod built in the late 40s as possible. If that means it does not drive or handle like a new car so be it. I am going with a flathead, old manual steering, drum brakes etc, so there are a few more things that won't work like the latest technology and I ain't worriying about them either In my book, ya gotta be true to what you are building, If you want something that is a mishmash of different eras and technology, thats ok too, but you should decide which way you want it to be. -Dave
Please yourself, if it is the look that you want then run 'em. I got a set of wheels wth radials and another set with traditional bias and change 'em to suit my driving and mood.
