I'm looking to use 3 94's on my hemi and have been looking around for a good source. I have seen various bad reports for Vintage speed although they seem to talk a good game, and have seen someone from Canada doing a 3 twos set up for $750 on ebay. Anyone any comments on either, or suggestions for a good source? Thanks
I'm always concerned that "for rebuild" can often mean "for bin"! Its not too bad if you can have a good look inside first at a swap meet, but ebay makes me a bit nervous. I've had some offered locally for $80 each that need a rebuild kit but are apparently good. Depending on what else I can find I'll take a ride over and have a look.
Try this fellow ahttp://www.jalopyjournal.com/forum/showthread.php?t=220930 Definitely avoid Vintage Speed at all costs.
A member on the Shoebox Ford forum bought two carbs from the Canadian eBay guy. He said he didn't like the finish on one of them and the guy sent him a replacement no questions asked. He was very pleased with them.
I got the rebuild kits for my three carbs from Vintage Speed. Everything seemed to go ok. Will 3 94's feed a Hemi?
Depends on the Hemi. Is it stock? Cubic inches? Cam? Should be fine for a stock spec. motor and maybe even a bit more. Depends on the series of 94's also. Some flow more than others. Average is probably around 170 or 180.
Oh, BTW... Charlie Price (owner of Vintage Speed) is out of the shop till the 9th. Not sure if that will delay your order, but just thought I would pass it on.
Three 94s might work on a very small Hemi, 241 ..270..Dodge...I think the Hemi would run lean if bigger CIs.. Duane. ps..dickster27 might be the man for 94s.
Yip, there is a difference in 94's that go clear up to a special hi-performance version Holley made in '62-'64 until they discontinued the 94 style to be replaced with the pancake style you now know. 160-300 CFM are indeed available. I know that those figures will be disputted but most folks don't even know Holley made a big 94. I have them all and the hardware to get it together for you. Not makin' a hustle here, just letting you know there is a place to get all your little carbies played with.
Thanks for all the info guys. Motor is a 330 Desoto Hemi that will be running one of the inlets fabbed by "38moparfan" (check out the thread if you haven't already, its a very nice piece of kit). Anyone have a name for the Canadian supplier? Replied to your PM Dickster, thanks.
You can also call Rudy Faltermeier in North Carolina - mine came from there. Beautiful pieces, my car is not running yet, but he came highly recommended from another HAMB'er who has used him for years. You can search him on the HAMB too, several posts. Rudolf Faltermeier 150 Rock Bridge Rd Spartanburg, SC 29307 864-463-6052
Don't get me wrong, I love the 'ol 94, but I'm mostly a Stromberg/Rochester guy. They "do it" for me! ...I already have glasses. ~Jason
I would call Jere Jobe. The guys at Edelbrock say he is the 94 guru. I bought two 94s and an intake for my flathead from him. He set the 94s up for my engine, put the carbs and intake on a test stand flathead in his shop so he could run and adjust them. I bolted the complete intake assembly on and it ran like a champ.
Don't forget that the cfm requirements for the engine is based on OPERATING rpm... if you always run your engine at 6,000 rpm's you'll need more cfms. But, in a normal street drivin application, you can easily operate with a lot less carburation. Back in the 60's the "normal" 3X2 setup for everything (292 Fords, 389 Pontiacs, 371 Olds, Flatties, etc) was three 97's or 94's. See we didn't know, or care, about cfm's, cam durations, etc. We were dumb BUT we had some pretty neat (and fast) cars. My point is 3 97's will feed a 392 Hemi if you don't peg the tachometer. A 330 DeSoto would LOVE to have three 97's/94's...
EXACTLY! What Krooser said! Guess it all depends on your plans. Also, it depends on the efficiancy of the manifold as well and the way the runners are laid out. If you use the 3x2 adapter that goes on 4bbl manifold it's going to have different flow characteristics than say an open plenum type 3x2 or even a single log style 3x2 like Lake Headers fabs up.
Great help and info guys. I've read a couple of pieces by Jere Jobe and he obviously knows his stuff, didn't realise he supplied as well. The reserch continues..........
