Tie-rod end drops?
Discussion in 'The Hokey Ass Message Board' started by fast41, May 20, 2008.
  1. fast41
    fast41
    Can someone give me the skinny on tie-rod end drops? I have 4-inch drop axle in a F-1. I need to know where to purchase them. Thanks!
  2. DE SOTO
    DE SOTO
    I bought some for my '55 F~100 from BOBS F-100s in So.Cal. years ago.
    But they didnt work with a 4" axle, He said would but they didnt.
    Kinda scary looking lil buggers to, My truck at the time ran the 223 6 so what i did was heat the stearing arms & bent them UP to the cross link went OVER the leaf spring.
    Ran it like that, NO problems ofr a couple years till i switched in a Pontiac V8... Then had to make Deep dropped steering arms to clear the Oil pan of the V8
  3. old beet
    old beet
    The ones that I bought for My F-1 years ago I could have made myself. Simply a tie rod end cut in half and welded to a 1/2 inch plate. A plate about 4 X 2 inches, hole drilled in each end, insert cut tie rod and weld. Lookin hokey but worked...........OLDBEET
  4. old beet
    old beet
    Whoops! Not that hokey is a bad thing...............OLDBEET
  5. Check with Cen Pen speed, got some for a 64 F100 from them.
  6. Maybe you'll get them within a month.
  7. fast41
    fast41
    What do you mean welded to a plate?
  8. sociallydistorted
    sociallydistorted
  9. old beet
    old beet
    Picture this: 1/2 inch plate,(2 X 4 inch )
    drill a hole (size of the threads on tie rod end)
    on each end of the plate llOlllllllllOll
    cut tie rod off thru threads, about 2 inches in
    stick threaded end in one hole
    stick knuckle end in other (opposed from each other)
    weld in place
    now you have a dropped tie rod end
    hope that makes sence..............OLDBEET
  10. fast41
    fast41
    I guess the Florida heat is getting to my noggin. I can't seem to follow this. Please explain again, Thanks!
  11. cheddar
    cheddar
    from missouri
    mid fiftie f-100 parts
  12. fast41
    fast41
    Is there any way to have a machine shop make them? All of the "parts dealers" only offer them for a 3" axle and I have a 4" axle.
  13. 35Chevy.com
    35Chevy.com
    from New Jersey
    My brain must be frozen from this New Jersey cold!
    Because I dont get it either, any pics?
    Gary
  14. Seems like it would flop around in use. Someone must have a photo.
  15. old beet
    old beet
    llll steering arm
    lllllllllll
    tie rod llllllll
    Best I can do!...........OLDBEET
  16. old beet
    old beet
    Draw a verticle line above the "D" and that will be the plate that connects them together. Or, bolt the tie rod end to the steering arm, now hold the tie rod about 3-4 inches below that, picture a plate that fills the void.
    I can hardly operate this PC, let alone send brain waves...........OLDBEET
  17. I found some on ebay with a photo, still don't see how they work.
    http://cgi.ebay.com/ebaymotors/Tie-...xles-Ford_W0QQitemZ260241328368QQcmdZViewItem
    "These drops will drop your tie rod 2" from stock. These work with the 1937-48 Ford car or the 48-64 Ford 1/2 ton pickup truck 7 degree tie rod ends. These blocks bolt to steering arm with grade 8 bolts thu tie rod holes on steering arms, then the tie rod end comes in bottom 7 degree hole and tie rod end nut goes in U-slot in block. Drop blocks are great for F-1 and F-100 with dropped axles."
  18. fast41
    fast41
    That would make it look like this.....
    <<TR<|
    |>TR>>
    This would make the tie rod ends horizontal when they need to be vertical like this.....
    ^ This end into the bottom of the steering arm
    TR
    _____
    |__TR_ Tie rod end goes into this end from the bottom
    Now I am even more confused! I guess I'm a closet tard!
  19. striper
    striper
    I could do with something like this but all of it sounds very dodgy. I think I'm gonna just put a drop in my tie rod.
    Pete
  20. nexxussian
    nexxussian
    You and me both evidently:confused::confused:.
  21. ProEnfo
    ProEnfo
    from Motown
    CC..
  22. old beet
    old beet
    THANK YOU!!!!!!!!!!!!!!!!.............OLDBEET
  23. nexxussian
    nexxussian
    Duh Hah!
    Thanks Pro Enfo.
  24. fast41
    fast41
    Has anyone ever put a drop in the steering arm itself?
  25. old beet
    old beet
    You can heat and bend the arms, let them cool slowly......OLDBEET
  26. fast41
    fast41
    Sorry, I meant to say the tie-rod bar that goes from side to side.
  27. OLLIN
    OLLIN
    I am in the process of doing this now. This looks sort of like what I have, but a few people that have looked at it were suggesting I redo it better.
    I was thinking of bending the actual tie-rod with a tube bender? would this work also?
    I like the bent vega tie-rod end idea also since they are longer. or just look for the willys ones...
  28. OLLIN
    OLLIN
    oops, in the time it took me to post, my first questions was answered!
  29. old beet
    old beet
    Yes you can drop the bar. Cut both ends off, lower the center section, then heavy gussets are a must. Adjustment is tough. If you simply bend a longer bar, it will bend forever. On my F-1 with a 4 inch dropped axle I heated and lowered the steering arms and used modified tie rod ends as pictured. Drove it that way for 20 years. Then went to Mustang II. Lower and a much better driver, nearly 400 K miles now.....OLDBEET
