32-34 pickup pics?
Discussion in 'The Hokey Ass Message Board' started by wes, Oct 6, 2003.
  1. chop509
    chop509
    Anyone have more pics/info on this one?
  2. englishhemi32
    englishhemi32
    heres mine, running daimler v8 (english) with a 1966 volvo amazon 4 speed manual and mustang 8" rear, superbell front with f100 brakes, mexican rug headliner.
    31hotrodguy likes this.
  3. Flat Ernie
    Flat Ernie
    Tech Editor
    I've seen your truck at a couple of the runs when I was living over there - it's very nice! I like it a lot! :D
  4. 2-TONED
    2-TONED
    By deucecabriolet
    heres mine. its now undergoing a change, ---- gettin lowered right now, the bone is split & drilled with pipes welded in, buick drums, new brakes.
    the chrome reversed w/spiders & dropped light bar with deuce lights are already on & the front bumper is in the garbage. -
    & before spring the 283 will be removed. the firewall will be painted something 'wild' & different & a nicely detailed candy gold 327 will be going in probably with a tunnel ram.- (undecided on what intake.)
    i may then slice a little off the top (only a little bit though)
    By deucecabriolet
    here it is as bought off E-PAY. Nov. 08
    heres a 11/10 picture.
  5. fordsteel
    fordsteel
    from Elkland PA
  6. Here's my 34!
    31hotrodguy and kiwijeff like this.
  7. VAPHEAD
    VAPHEAD
    Any new projects out there?
    Or better yet update pic's??
    Lot's of 32-34 trucks being built I here
  8. Tuff Tin
    Tuff Tin
    I sold my 32 pickup in 72 and have been looking for it every since. It had a new 59AB Flattie and was 2 toned with maroon on the top and a peach color (kinda) on the bottom. Some one in the 50's made a set of stainless steel stacks up the cab complete with mufflers wrapped in ss. They were small tubes, about 1 1/2 inch. Man I miss that truck.
    It was last seen in Eatonville, Washington
  9. NAFTA
    NAFTA
    from Europe
    Hi...do you like?
  10. NAFTA
    NAFTA
    from Europe
  11. willie57
    willie57
    from wisconsin
    Here is my 33 ford body[​IMG]
  12. Kirk Hanning
    Kirk Hanning
    Here's mine hoping to drive it to billetProof in 5 weeks completely finished.
  13. 2-TONED
    2-TONED
    some fresh pics
  14. This is the 34 cab on 32 rails we have been working on,,had to quit for a while to work on other peoples projects,,
    Hopefully in a few more months we can get back to work and finish the truck. HRP
  15. ukgav
    ukgav
    Here's mine. Just waiting for it to be shipped over from Limeworks.
  16. D.SCOTT
    D.SCOTT
    this just makes me mad! been lookin for a cab in my vicinity for a year and nothin!
  17. Green Voodoo
    Green Voodoo
    from Melbourne
    Here is my Current project ( See Pics. Below )
    The truck is being restored as it was built in the early fifties ( including period correct castle nuts etc.) - no upgrades and no aftermarket parts whatsoever!
    There is nothing on this Hot Rod that was not available in 1956 or earlier.
    The truck features: 52/53 Olds Rocket engine, with weiand tri carb intake ( I am looking for a set of orig. hellings aircleaners ), weiand vally cover, 39 Lasalle trans, with correct period Ansen pro shifter, 40 Ford front end with stock axle ( Non dropped ), 40 Ford Rear end with shortened torque tube & radius rods , 51/53 Porsche tubular shocks( front ) , Ford tubular shocks - rear. 1938 Hudson steering box, , topped with 42 Buick indicators & steering wheel ( Was originally fitted with Hudson banjo steering wheel & i will replace the Buick item if i locate a suitable Hudson wheel), Modified - dropped centre trans x member & wishbone pivot mount, 40 Ford wishbone modified with 32 pivot section ( wider than 40 to clear engine), 8.20 x15 WSW tires - rear , 6.70 x 15 WSW tires - front , Rake - 2 1/2" , 1954 Ford brake and clutch master cylinder ( Staggered ), 54 ford Hand brake, , 49 Lincoln instruments with 120MPH speedo, and hand made aluminum dash panel insert, 50 Olds ( interior ) rear view mirror.
    Body Mods include : Nosed 34 Truck Grille sectioned 5 1/2" set vertically ( similar to 32 Grille) and bottom modified with inverted 32 commercial grille surround header,. Roof chopped 3 1/2" ,Cab channelled 5 1/2". Cab fitted with green tinted glass. Custom Roll Pan, Custom built pick up bed stake pockets, Shortened pick up bed with bevelled ends, Dropped 5" Headlight bar fitted with 682 BLC Guide headlights, 50 Olds 98 Tailights centre mounted on rear fenders. 49 Desoto front bumper ( cut down ).
    The number plate fitted to the truck is the last CA registration #: FSC 088, tagged 1965. The number plate light is the original early 50's Hollywood accessories assembly ( small script type )
    The two tone interior featured white vinyl with fine pleated green nylon inserts.
    The truck was painted deep purple with white firewall and grille insert.
    You will note the paint color ( Purple ) on the cowl vent in one of the photos - the color was exactly matched to the original paint color.
    It appears the truck was first built in the early 50s when it was painted dark green with a red firewall and chassis. At that time, it was possibly fitted with a flathead and then later upgraded to the current specification - Olds engine, Lasalle trans etc. in about 1955/6.
    Our research found 3 of the mods incorporated in the truck were featured tech articles in Car Craft magazine during 1955. They include the staggered late ( 1954 ) Ford master cylinders, the 54 Ford Hand Brake, and 50 OLDS 98 tailights.
    The truck was discovered in Orange county, California in 1996.
    We are trying to source any information on the truck, such as the builder,magazine features/ articles, if any, etc.
    Mike Nicholas
  18. thunderbirdesq
    thunderbirdesq
    I don't have any info on it, but that truck is awesome!!! Way to go!
  19. fordhaulers
    fordhaulers
    my next project
  20. Here's what I've got so far.
  21. Low Fat 38
    Low Fat 38
    from Norton,Ma
    Hotrodprimer, The truck looks great! where do you find body patch panels? did you fab up your own? Again nice job.
  22. spoony
    spoony
    from L.A.
    here is my poject
  23. PAUCHO
    PAUCHO
    Here's my old 34....It sat kinda funny, but at the time I thought it was perfect...[​IMG]
  24. Thanks,,yeah,we fabed up the bed and sub rails identical to the one on my truck,,,new brookville hood,shell and front fenders,,,the cab is nice so no patchs yet. HRP
  25. Stitchn
    Stitchn
    I have mine in the body shop now, frame complete & going back together. Check out (spy pics 32).
  26. 2-TONED
    2-TONED
    added another pic as it went through another change.
    drove it over 3000 miles in 3 months.
    i do keep the old tire cover on the spare now. i just had it off for a week or 2 & the back tires wont be hangin out by this spring. i think...hope anyway!
  27. PAUCHO
    PAUCHO
    Here's another picture of my 34.....It's me and my girlfriend in the 70's.....
  28. bigken
    bigken
    Not a dang thing wrong with the way it sits...........:D
  29. BigKen and I got our trucks on the road about the same time,,,,I would love to have the extra cash to buy another one and build it as a hiboy,,,HRP
  30. bigken
    bigken
    Funny you say that - I've secretly been wanting to put my fenders and boards on......
