I have an application chart that lists the Edelbrock C362S intake as using big base 2G carbs, and others that say it uses 94/97 three bolt carbs. Does anyone have one? I'd like to know for sure before I start looking. Thanks, Rob
What engine are we talking about? Edelbrock's current 3x2 manifold for a small block Chevy is C-357-B, carries a part number of 5419, and takes 4-bolt carbs. Check it out here: http://performanceparts.com/part.php?partID=135874
I have a C-362 set up.The manifold does use the large Rochester 2 bbl.carbs.4 studs. Its not drilled and tapped for 3 bolt carbs. I havent used it yet so I cannot tell ya how it works... By far,most of the used 3X2 manifolds you see use the small base carbs and I suppose you could put the smaller ones on with adapter plates if desired.
Thanks, I was hoping it was for the big based carbs (which I have lots of). Now I just need to find the manifold. If anyone has one available, let me know. Rob
I'd assume that it would the same manifold. I'd be surprised if they cast a different intake for the small based GC's and a three bolt carb. I would assume you could drill & tap for the center bolt for a 3 bolt carb, no?
